1. Dismiss Notice
    Dismiss Notice
XS650 No Theme Build
Discussion in 'The Garage' started by halfmile, May 24, 2018.
  1. CoconutPete
    CoconutPete 1979 XS650 Special
    Ahh ... those welds....:bow2:
  2. halfmile
    halfmile XS Builder XS650.com Supporter Top Contributor
    1,032
    2,852
    263
    kansas
    Thanks Pete. This is certainly not my "A Game" by any means but it will have to do. I already have ideas for another build and don`t even have the frame for this one finished yet.:shrug:
    Jim likes this.
  3. halfmile
    1,032
    2,852
    263
    kansas
    Didn`t do much today (too many interruptions). I did finish up the upper motor mount and relocate the brake stay bracket to eliminate the rear drum mag and go to disc.
  4. halfmile
    1,032
    2,852
    263
    kansas
    Spent the entire day Boxing the Bishop on these saddle washers. Need these to mount my left over skid plate. This is the last thing to do before the powder coat/ I think.
    Jim likes this.
  5. fredintoon
    Hi halfmile,
    I can tell you about the "something with a little door" because my Heritage Special also has one.
    It's a container for the factory-supplied security chain that uses the bike's ignition key to work it's lock.
    Most likely the chain itself was long gone or you'd have wet yourself laughing at it.
    The chain is more suitably sized to be a dog leash than a bike security chain.
    So long as the dog don't weigh more than 20 lbs.
    Jim and robinc like this.
  6. halfmile
    1,032
    2,852
    263
    kansas
    Thanks. I had no idea what that was. Maybe they should have used security "String". I gave all the stuff to Jim anyway.:shrug:
    Jim likes this.
  7. halfmile
    1,032
    2,852
    263
    kansas
    Got the saddle washers installed on the frame and the lifting spool and brake stay brackets welded on the swing arm. I might put the powder coat on hold until I make the exhaust system (TT Pipes) in case I need to weld some more tabs. Hoos makes nice ones but I don`t know if they`re long enough to clear the skid plate. I didn`t like the skid plate in the first place but since this build has no theme I need to use up as many spare parts as I can. Easily removed however?
    skid plate 001.JPG skid plate 003.JPG skid plate 004.JPG skid plate 005.JPG skid plate 006.JPG skid plate 007.JPG skid plate 008.JPG
  8. 59Tebo
    59Tebo 59Tebo Top Contributor
    Wow!!! Mad skills! Hurry up and finish it already, will ya, so we can nominate it for the calendar!!! :rock:
    Jim likes this.
  9. halfmile
    1,032
    2,852
    263
    kansas
    Thanks 59Tebo. I`m just a simple lottery win away from wrapping this build up. It seems my "Budget" build has gone to Hell in a Hand Basket! Did last a little longer than usual though.:doh:
    robinc and Jim like this.
  10. 59Tebo
    :laughing:
    My budget went to hell a loooooong time ago....
  11. Jim
    Yeah... that's the story of my SG build.... "hurry up and wait." :(
    Lookin' good Phil!:)
    59Tebo likes this.
  12. halfmile
    1,032
    2,852
    263
    kansas
    Got a few min to work on the no theme build. Mounted the Chinky MC and made simple stop & return spring. That was the only simple thing because drilling the holes and tapping the threads turned out to be a giant PITA. Just wasn`t long enough:yikes:. (regular length drill bits that is). Thank God for Boeing Air Craft Surplus bits. Awkward to get the right angle for a straight push but it works great. So much for that Sept 1st powder coat :shrug:.
    brake lever-stop 017.JPG brake lever-stop 018.JPG brake lever-stop 019.JPG brake lever-stop 020.JPG brake lever-stop 021.JPG brake lever-stop 022.JPG brake lever-stop 023.JPG brake lever-stop 024.JPG brake lever-stop 025.JPG brake lever-stop 026.JPG brake lever-stop 027.JPG brake lever-stop 028.JPG
    59Tebo, geedubya, robinc and 2 others like this.
  13. Superjet
    Superjet XS650 Junkie XS650.com Supporter Top Contributor
    Pretty neat build so far Halfmile! Very nice fab work indeed!
    Moabite and Jim like this.
  14. halfmile
    1,032
    2,852
    263
    kansas
    Deja vu?? Seems like I`ve done this before! Spent the last 2 days dressing up the substandard factory welds and removing all the slag and spatters and sandblasted the frame and swing arm ready for powder coat. Only a month behind schedule.:shrug:
    sand blast no theme 001.JPG sand blast no theme 002.JPG sand blast no theme 004.JPG
  15. halfmile
    1,032
    2,852
    263
    kansas
    Move along folks. Nothing to see here. Took frame and swing arm to powder coater today. Finally!:thumbsup:
  16. halfmile
    1,032
    2,852
    263
    kansas
    Started the process of drilling the wheels. First I made a template for the outer rim on the rear wheel. Drilled 60 2mm holes, 60 3mm holes, 60 4mm holes and 14 6mm holes. Will smooth out the chamfer tomorrow and make a template for the spokes and drill them. Then the front.:thumbsup:
    Wheel Drill 001.JPG Wheel Drill 002.JPG Wheel Drill 003.JPG Wheel Drill 006.JPG Wheel Drill 007.JPG Wheel Drill 009.JPG Wheel Drill 010.JPG Wheel Drill 011.JPG Wheel Drill 014.JPG Wheel Drill 015.JPG Wheel Drill 016.JPG Wheel Drill 017.JPG Wheel Drill 019.JPG
    Mailman, Robert Reed, willis and 5 others like this.
  17. halfmile
    1,032
    2,852
    263
    kansas
    Finished drilling and chamfering all the holes in the rear wheel. Still needs another day of detailing before paint. Front wheel is next.:thumbsup:
    wheel holes 004.JPG wheel holes 005.JPG wheel holes 006.JPG wheel holes 007.JPG
    TwoManyXS1Bs, 59Tebo, robinc and 2 others like this.
  18. Jim
    I'm guessin' you don't need my rear wheel then?
    Btw... looks good:thumbsup:
  19. halfmile
    1,032
    2,852
    263
    kansas
    I don`t know if I like these or not so don`t count me out yet. Now I have to make the front match the rear. When they`re done I`ll take a close look and believe it or not I have been known to change my mind. (usually everyday)?:shootme:
    Jim likes this.
  20. 59Tebo
    Did you happen to weigh them, before & after to determine how much weight was lost by making them "holey"? I saw pictures of the perimeter holes in a "rain gutter" spoked rim. I thought it was very cool, but not necessarily practical/functional. Just another small detail that raises the overall 'custom-ness' level of the whole build. But, as Hugh (HHB) once said "...less weight equals free speed!..." :bike:
    Jim likes this.
Share This Page
