1. Dismiss Notice
    Dismiss Notice
XS650 No Theme Build
Discussion in 'The Garage' started by halfmile, May 24, 2018.
  1. Jim
    Hmm.... just noticed the "hidden" pigtail. Nicely done bro. :D You always take it to the next level...
  2. halfmile
    halfmile XS Builder XS650.com Supporter Top Contributor
    1,032
    2,852
    263
    kansas
    I got lots of practice on the Go Karts. Everything had to be pinned or safety wired. The last pic explains the only 2 theories of Kart racing!
    One: you can never have enough carburator`s
    Two: you can never add too much Nitro.:yikes:
    Margay Ft Brakes 022.JPG New Panther-X 016.JPG New Panther-X 003.JPG C-OPEN 001.JPG ebay june 2015 021.JPG Hanson Duncan Motor 002.JPG
    Mailman, gggGary and Jim like this.
  3. 59Tebo
    59Tebo 59Tebo Top Contributor
    The brake rotor is so cool! Safety wire looks so much better than those stupid tabs... How many other places on the bike could you use safety wire? Rear sprocket, fuel lines... Where does it end? I dunno, but I'm willing to find out! :rock:
    Jim likes this.
  4. halfmile
    1,032
    2,852
    263
    kansas
    Drilled the rear rotor to match the front. Masked and ready for that 50 degree (paint)day tomorrow.:thumbsup:
    brake rotor 001.JPG brake rotor 002.JPG brake rotor 003.JPG brake rotor 004.JPG
  5. Jim
    Holy moly....... ;)
  6. halfmile
    1,032
    2,852
    263
    kansas
    The motor I`m going to use in the build had been painted silver then flat black (everything). The sad thing is it ran great and was spotless inside with clean oil and no debris in either of the filters. The paint to PO used was total Wallmart Crap :poo: so it was easy to strip and wipe off with solvent. I dressed all the rough edges on all the fins and rough sanded them, masked the necessary openings and painted with a semi-gloss black. Ceramic type. After the paint passes it`s critical period I`ll remove it from the edges of the fins and detail them. Trying to get this piece of junk on it`s wheels before the snow flies.:thumbsup:
    engine paint 001.JPG engine paint 002.JPG engine paint 003.JPG engine paint 004.JPG engine paint 005.JPG engine paint 006.JPG engine paint 007.JPG engine paint 008.JPG engine paint 009.JPG
    MrBultaco, 59Tebo, GLJ and 5 others like this.
  7. gggGary
    Ooh, bet we are both champing at the bit to see that gem revealed!
    59Tebo, Mailman and Jim like this.
  8. Jim
    Was kinda disappointed I didn't see holes in the fins... :rolleyes:
    Superjet and 59Tebo like this.
  9. halfmile
    1,032
    2,852
    263
    kansas
    Funny you should mention that? I`ve got another head ready to be ported and I plan on drilling holes in both the head and block fins. Already planning another project and this one`s not even on it`s wheels yet. I must be doing something right!:yikes::umm::shootme::shrug:
    MrBultaco, 59Tebo, gggGary and 3 others like this.
  10. Mailman
    This just might be your sharpest looking motor. They do look good painted black and I like the treatment you did on the edge of the fins! :thumbsup:
  11. halfmile
    1,032
    2,852
    263
    kansas
    Almost done removing the paint from the fins but I`m on the fence about this. I don`t think I`m into painted motors. Maybe after all the polished tappet covers and chrome upper mounts and other stuff I`ll like it better.:shrug: Vapor Blast next time.:thumbsup:
    MrBultaco, delagem, Superjet and 5 others like this.
  12. Jim
    I feel ya bro. Me either.
  13. 59Tebo
    Yeah, me three. Not a huge fan, but that looks really sharp. If the rest of the build went with it, it could be a snappy looking bike... :cool:
    Jim likes this.
  14. gggGary
    Well I think it looks great!
    Jim, MrBultaco and delagem like this.
  15. Superjet
    Superjet XS650 Junkie XS650.com Supporter Top Contributor
    The engine looks great Halfmile. I opted for the midnight silverado edition for my Roadstar cause of the black engine and silver fins. I am not into engine paint either unless it is from factory. My 83 came with a silver painted engine which was messed up. Took some lacquer thinner to it and cleaned up some but man its hard to get in all the cracks when its all assembled. Still have parts to scrape/remove off. 20170228_184517.jpg 20170228_184503.jpg
    Jim likes this.
  16. halfmile
    1,032
    2,852
    263
    kansas
    Well I guess it looks a little better with the masking paper off and a few polished component`s back on. I`ll install new clutch rod seal and bushing and maybe a shifter shaft seal and as far as I`m concerned the "Flat Rate`s Up". Time to put the engine in the frame and live with it. Looks better than the before pic.:yikes:
    JAX71224, Moabite, Superjet and 7 others like this.
  17. 59Tebo
    It does,indeed, halfmile. I hope to make a similar transformation to the engine in "The Basketcase". But, that is another story... :wink2:
    Jim likes this.
  18. halfmile
    1,032
    2,852
    263
    kansas
    Today I laid the motor on it`s side and put a block under the cyl fins to level it, lowered the frame down over it and put in the bottom and rear lower mounting bolts, then sat the frame-motor upright. Took about 30 seconds and not a scratch.:thumbsup: It`s 98% done! Just a couple more minor things to do.:laugh:
    motor-frame 002.JPG motor-frame 001.JPG motor-frame 003.JPG motor-frame 004.JPG motor-frame 005.JPG motor-frame 006.JPG
  19. Jim
    There's an old saying in the homebuilt airplane world..... the last 10 percent of the build, takes up 90% of the time. :rolleyes:
    Mailman, 59Tebo, Moabite and 3 others like this.
  20. halfmile
    1,032
    2,852
    263
    kansas
    Yeah, just needs wired and a little TLC to finish. "Sound`s just like a CL ad".
Share This Page
