xs650 scrambler build
IMG_5332.jpg IMG_5334.jpg IMG_5333.jpg IMG_5335.jpg started mocking some stuff up and cutting some of the tabs off going to try and make a tray under the seat today.
Another member posted this template quite a while back. I’ve always wanted to build one but never got around to it. It looks pretty straight forward though.
well had some fun tonight a put on the rear shocks got kinda sketchy lol
im having truble with the mikesxs wiring harness i got ive been searching high and low for this and cant seam to figure it out.... how to hook up the coils to the harness lol and how to properly delete everything on the handle bars moving starter by key on batt box having a light thats always on with the key is on..... but the main thing im working on is the coil wiring thanks guys !
If you are using the 2 original coils then one of them connects to the grey and red/white wires to the left in the picture and the other coil is connected to the orange and red/white wires to the right. You may need to change the grey and orange connectors to male bullets to suit the coils' female bullet connectors. Can you post a picture of the coil connectors?
ya your right i will one is a male and one if female on the coils also quick q how would i go about deleting my kill switch and relocating my starter button ? unnamed.jpg do i just need to take the 2 red wires and tie them together and hook the blue to a switch with the other side of the switch to ground ?
One of the red/white wires is from the fuse box and feeds power to the starter solinoid via the start switch.The same red/white wire feeds the coils via the kill switch. You need to determine which red/white wire that is and run it to the other red/white wire to feed the coils and also run it your start switch. The starter solinoid is grounded not the switch.
Thanks dude !
Wait! I take all that back. Your comments are correct. Tie the red/white wire together to eliminate the kill switch and for the start switch connect the blue/white wire to one side and ground the other. Your start switch needs to be momentary.
Lol ok cool
So im trying to hook up my ignition switch / key switch and cant figure out how hat wire what terminal on the switch after doing some searching I think this is the plug that I need to use
AE02B3A2-E300-4BF7-8294-4D5C73CE1673.jpeg C26C6E76-FC7E-4A9A-86B5-A3200BEB8F9D.jpeg 26660F6D-6E93-40EB-976E-9AF4B60D551B.jpeg EBA21517-6963-4201-8229-6D6520880510.jpeg Got the frunt half of the wiring neetly tucked away got the bike running again and put a head light on it happy with the way this is turning out.
have to do some carb work on her it seems to not want to run when i put any filter on the carb so im thinking its rich but we will see other than that it runs good
O ya and i cut the fender going to be getting a new seat to cover the hole lol
First time welding made a fue holes lol need to grind the hell out of it lol but battery box made and cut all the top tabs off the top part of frame
started bolting everything in to the batt box and wow im so happy how everything is fitting ! IMG_5513.jpg IMG_5519.jpg
ps i do have some white smoke coming out of the exhaust i dont know if thats from being way to fat or something els this is what my plugs look like (if i was sitting on the bike) Left side right side im going to get into the carbs this weekend.
