I installed new EBC pads, aha you say! I have done quite a lot of research already but have failed to solve the squeaking. If I jack the bike up and hand turn the front wheel, either fast or very slowly, the pads make a constant squeak. I thoroughly cleaned the brake calipers and chamfered the brake pads before installation.
When I rotate the front wheel the constant squeak is coming from the left pad. If I carefully put my fingers between the caliper and wheel and gently touch the left pad the squeak stops. The squeak went away for about five minutes when riding after having slightly bent the left shim plate. The squeak stops if the brake is applied very lightly.
Any suggestions as to what to try next???
Also, what is the purpose of that screw (Item #5) that goes into the left side of the caliper and fits into a hole in the left brake pad???
Thank you.
Thank you.
