XS650B master cylinder rebuild Q's
scott s
XS650 Guru
Rock Hill, SC
Tell me about rebuild kits for the XS650B master cylinder.
In the M/C for my '75 XS650B, I can move the plunger with compressed air and I can squirt brake cleaner through it. The plunger doesn't return on it's on, though. I see in the diagrams there's a spring in there....maybe my spring is stuck or??
It looks like I need to remove a snap ring or circlip and pull out the plunger assembly.
I know it's the same as several early RD models (75-76 XS650, 72 XS2, 73-74 TX500, 74 TX650, 76-78 RD400, 73-75 RD350, 73-75 RD250) and is part #1A0-W0041-00-00.
I also found one for a 1976 RD200 1979 RD400 1980 TZ250, Part #: 535-W0041-10. Is this the same kit?
Maybe there's a 2 stroke site out there that details the rebuild of this early style M/C?
MikesXS sells special circlip pliers for reaching that circlip at $10 m/c circlip pliers
Master cylinder rebuild kits are available from 650Central but they are nearly $80 :yikes:
650central
1975 front brake m/c diagram
part # for a repair kit is 360-20000-20-00 and fits these models
TZ750A - 1974
TX650A - 1974
XS650B - 1975
XS650C - 1976
XS2 - 1972
RD250 - 1973
RD250B - 1975
- 535-W0041-10 is not the same kit
- i have an XS2 Supplementary Manual that runs you through it, also an XSB Manual
Thanks guys, especially Inxs for that link. I actually have a set of snap ring pliers but they're about thiiiiis much too short. Need to pick up a longer pair.
I have the same problem finding a rebuild kit.Can anyone confirm that this is the correct kit part #1A0-W0041-00-00
1A0-W0041-00-00
XS650B - 1975
Assembly: FRONT CYLINDER KIT, MASTER (360-200 (SKU: 1A0-W0041-00-00)
APPLICATIONS
RD250B 1975 250 RD250 Street
RD350 1973 350 RD350 Street
RD350A 1974 350 RD350 Street
RD350B 1975 350 RD350 Street
RD400C 1976 400 RD400 Street
RD400D 1977 400 RD400 Street
TX500 1973 500 TX500 Street
TX500A 1974 500 TX500 Street
TX650A 1974 650 TX650 Street
TZ125G 1980 125 TZ125 Road Racer
XS500B 1975 500 XS500 Street
XS650B 1975 650 XS650 Street
XS650C 1976 650 XS650 Street
- try here
I've got the same problem. I'm wondering, is there a different front master cylinder that will swap on for a more reasonable price?
Mike's only carries rebuilds for the newer (77-84) kits or his replacement master cylinders. I've got the older round type master cylinder.
I'm wondering if there is a later model Yamaha master cylinder that will work with the XS brake line fittings?
