some amazing info about cams and valve clearances on xs 650 aw crap that sidnt work
maybe this link will
http://www.smedspeed.co.uk/tech.html#top_anc
these guys are outa britan
XS650 CAMS
The XS650 has relatively recently gone through quite a rebirth, although its popularity in the late 80s and 90s waned, with the interest in vintage Japanese bikes at an all time high, it is only right and proper that the best Japanese twin made should be at the height of this interest.
There are a whole host of improvements available for these bikes and there are many manufacturers worldwide who will provide parts and services to keep these twins alive. I supply a few of them, rephasing is one of the best known current modifications. There is an upgrade for almost every part for the bike that is “evolution”. These bikes, like every commercial enterprise, were built to a price and some of the design reflects this. However, now many have the luxury of an attentive owner who is quite willing to improve the original design by spending money on quality upgrades.
One of the improvements possible, although not one often addressed , is cam shaft replacement. The XS650 camshaft was never a performance item; its design brief would have called for good fuel economy, ease and cheapness of production and reasonable power for an engine of its type. Recently I set up a dial gauge and measured the valve lift, measured against crank rotation. I have done this dozens of times to check what the valve is actually getting lifting, compared to what the cam vendor or manufacturer states.
What I found was quite a revelation to me. I was fully aware that cam design along with everything else has taken huge leaps forward since 1968/9 when these engines were on the drawing board. The cams in an XS650 both early and late styles lift the valve of the seat very slowly.
These are the figures for the inlet valve lift measured at degrees before top dead centre (BTDC)
Inlet valve lift
Degrees BTDC
0.002
93 BTDC
0.004
71 BTDC
0.006
49 BTDC
0.040
11 BTDC
0.050
7 BTDC
Similarly the inlet valve closing after top dead centre ATDC
Inlet valve lift
Degrees ATDC
0.050
43
0.040
47
0.006
77
0.004
95
0.002
122
If the inlet valve tappet clearance is set at 0.002 the overall inlet cam timing event is 93+180+122 = 395 degrees, if the tappet clearance is opened up to just 0.006 then the inlet cam event total is 49+180+77 = 306 degrees.
The late XS650 stock cam holds the valve off its seat for nearly 45 degrees before it actually lifts more than 0.005; this is just wasting power, and compression.
Setting the intake valve clearance at .006" versus .002" means you have lost 89 degrees of the valve opening event. (44 degrees on the intake opening side and 45 degrees on the intake closing side) It won’t lose you any flow or power however, as the valve was only a couple of thousandths of its seat.
The intake valve is just loitering off the valve seat but is still open when it could have opened 44 degrees later, and closed 45 degrees earlier, allowing for greater dynamic compression, and more time for the valve to lose its heat through the valve seat. There is no flow advantage with the slow opening and closing rates that leaves the valves open for 89 degrees a few thousandths off the seat except burned valves, lost mixture and compression.
The early Yamaha XS650 ( XS1, XS2 etc) had tappet clearances of 006" and .012" for the intake and exhaust respectively. It’s one of the reasons the earlier engines perform better, they do have a slightly wilder camshaft (not much) but most of the increase in compression comes from just keeping the valves shut longer .
Setting valve clearances to the LATE stock cam specs just contributes to reversion and lost compression with these antique slow cam lobe opening and closing rates.
The design of the cam echoes the “cooking model” cams of the British bike industry, but as Yamaha engineers had no previous four stroke experience what else could they copy err…. benchmark.
I have checked stock and performance cams from the opening to the closing in thousandths per degree every 10° of crank rotation, just to check cam profiles. Most of the newer design (non symmetrical) cams open the valves faster than they close them, but both rates are very much faster than the old style cam designs of the past. Computer modelling cam profiles helps in this area.
The late XS650 cams set at .002" intake tappet setting is ridiculous. I can’t think of another OHC engine with valves this size that has such small clearances, the camshaft has a run-out of over 0.002 in many cases and setting the tappets to this small clearance will allow the valve to stay open perpetually. It is an effort by Yamaha to reduce engine noise, but this is not the way to do it.
I set all the tappet clearance at the early settings of 0.006 and 0.012. It allows in more oil, and allows for a generous growth in the metal parts, remember….. A loose tappet is a happy tappet.
BACK TO TOP
