Couple things - repair the outer sheath on your clutch cable with electrical heat shrink tubing. It'll fix it up like new. Then take better care routing it next time. Look at where and how it's running, and if anything will pinch it. Consider switching to the long one piece clutch pushrod. It works a bit better and is less prone to leaking. It also puts less wear and tear on the pushrod seal and bushing. Speaking of which, chances are you need a new pushrod bushing along with the seal.
