I continually see dire warnings of Doom and Gloom and threats of the sky falling down on your head if you dare to test your ignition spark without earthing (grounding ) your HT leads during the testing but I have never really thought about this until last night when responding to a post about non starting tests .
What is this all about ? can someone please tell me how you test for an HT spark without grounding the HT lead or spark plug ???? The very process of testing an ignition spark at the HT lead requires the HT lead to be held close enough to ground in order to obtain an arc (spark)
If you test for an HT spark by removing the spark plugs and holding them against the frame or an earthing point (ground) then again the HT lead is grounded by virtue of any spark being able to go to earth /ground via the spark plug body
The only situation where there may be a risk to an electronic ignition system is if the engine was cranked over with either of the HT leads loose so that the HT spark was unable to find an earth to dissipate to . Even in that event I suspect that it would take a lot longer than a brief couple of seconds to damage a TCI equipped bike which is all the time that it would take to test for a spark.
I may be wrong but think it is extremely unlikely that anyone is going to test for an HT spark on any bike TCI or other electronic ignition system without grounding either the HT lead with the cap removed or a spark plug that has been removed and held against an earth point except in the event of the caps of both HT leads being removed and only one HT lead tested at a time .
I think there is far too much confusing or misleading advice spread throughout the net when we don't take the trouble to give accurate information and warnings. The risk to a TCI or unprotected electronic ignition system is when the engine is cranked with the ignition on for other purposes other than testing for a HT spark and I cannot think of a reason off hand why you would need do that ...?
I welcome discussion on this, particularly from anyone who has taken a perfectly good TCI and tested it to destruction by cranking the engine with both plug caps off the spark plugs for extended periods
i just don't buy it . if TCIs were that fragile and flaky they wouldn't last 5 minutes in a high tension environment let alone 38+ years
