Foreign object found when draining transmission oil
I think this thread has taken a turn for the worse. We were trying to help and you seem to be pissed off due to that help. If the PO repaired it then say that. If you decided to ignore the problem and it is going ok, say that. We are all here helping each other out. I offered advice with that in mind. If you dont want me or any other member replying to your thread then say so. There are plenty of other threads to read and follow along without the crap.
Huh?
Common theme from this guy.
Apparently you want to argue
The wheel is for the detent.... it's what locks it in whatever gear you select. Without it the tranny wont stay in gear for more than a moment or two
Jim to the rescue. That’s what I was afraid of. For some reason the word “detent” was escaping me. But yes, having seen how that mechanism actually worked I couldn’t imagine how the tranny could work without it.
