dps650rider
Maybe, or possibly other problems.
BTW, mine chattered when new.
Amen brother! I wonder how much clutch separation the guys with hydraulic systems are getting? I can’t believe there never was an aftermarket solution for this. That little clutch worm just doesn’t have much side to side travel.
It's good to be in 1st holding the clutch in at lights, in case you need to haul ass out of the way quickly. Or slowly, as you're discoveringIt's often impossible to get into neutral when it's in first at standstill,
I'm often stuck at the lights holding the clutch in because I am stuck in first.
Can you tell me more about your hydraulic clutch setup. Is it described in another thread? ThxI got some generic radial master cylinders that turned out to be knock off Brembo RC19 pumps, at least I think they're fakes. Real Brembos seem unlikely to cost 85 bucks per pair . They look good, which isn't too important to me, and more importantly they work GREAT! I get full separation of the clutch plates now, I can easily find neutral hot or cold. My whole clutch setup should someone want to replicate it is late model dampened hub / 7 Alto frictions / 6 normal steels / one piece pushrod / hydraulic actuator from the German vendor / Ivan's primary with needle bearings / heavy springs from Mike's / (6) 6mm washers under the clutch spring bolts to allow more travel ( I was experiencing coil bind as the clutch stack wasn't quite the right total thickness). I'm going to try the thicker XS1 steels next time I have the cover off because that would eliminate the need for the washers under my clutch spring retaining bolts, or maybe I will leave it alone since it's working well enough.
This thread is quite interesting because I'm currently exploring the hydraulic clutch conversion for my bike. My bike has a MikesXS 750 big bore kit and has a true 270 deg rephased crank. The motor is still being run in yet, so still has running in oil in it.
I have the Magura clutch lever fitted and found that I was getting huge clutch slip problems, as well as not being able to select neutral unless rolling, even though the clutch was adjusted correctly. I realise that I still have quite thick.oil in it yet and this might be causing the neutral issue but not the slip. Anyway, i took advice from Smedspeed in the UK, who suggested i exchange the clutch plates to EBC kevlar race plates for an early R1. They fit straight in. After putting it back together the clutch slip disappeared completely, but I still couldn't get neutral. This is why I'm now exploring a hydraulic conversion.
So, I have acquired an Aprilia Tuono slave cylinder, as has been tried in another thread, though I can't find it again. I know I need a master with approx. 19mm piston, which ought to get me around 4mm of actuator rod travel. After looking around, I couldn't really find anything with that size piston that would compliment the front brake mc setup, which is the std XS cylinder. So I ended up buying a cheapo chinese pair of 19RCS Brembo lookalike levers. As expected, the piston dia. isn't 'adjustable' like a brembo mc is, but hey they cost buttons. Anyway, I jury rigged the mc and sc up and tested the actuator rod travel. I achieved 3.65-3.67mm. I'm not sure how this compares to my cable setup yet. I intend to test this once the bike is run in and it's time to change the oil. If I discover a significant improvement of travel from the hydraulic setup then it might persuade me to go the distance and modify the LG engine casing to accept the mc.
View attachment 196532 Above shows my jury rig setup. I measured the end travel of the dummy actuator with a digital verbier.
Do you have a link to your thread?I am not sure if you were talki
I am not sure if you were talking about my thread or not but from my personal experience what I found to be a great combo is the 28mm diameter slave cylinder and a 13mm master cylinder. I get ~3.1mm separation and am close to getting spring binding on the pressure plate. 3.4mm could be past the point of binding. I have no trouble finding neutral while rolling or with the engine running at a stand still. I also run an alto 8 plate clutch which alters stack height just a little so "ymmv"
