LTGTR
77D - stock BS38 carbs.
I recently removed my carbs and replaced a couple of things like jets and needle and seat and cleaned them with carb cleaner and compressed air. I now have them set up on the bench and hooked up to the fuel tank which is sitting above them on a crate, to check for leaks before fitting them to the bike.
The problem is there is a slight fuel leak into the throat of both carbys that is coming from around the part where the needle jet protrudes into the throat.
I didnt remove the needle jets when cleaning the carbs but I did rotate them so I could get a fine carby jet cleaning wire though all the holes.
I measured the float heights very carefully and cant see how the fuel level could be that high to cause it.
Would like to ask the forum's advice.
Regards Ray.
Regards Ray.
