Zonie
While replacing the headlight shell and fork ears along with installing a used cluster I needed to do a bit of re-wiring. There were some changes in the harnesses between the years. I have been able to borrow the special crimping tool but needed the correct connectors. The ones from Mikes XS were good but you have to order the insulation separately. Got some from Corsa Technic which come with the insulators and at a little less cost per connector.
So, If you ever need replacement connectors check them both out.
