Probably planning to park a Brit Bike in there...What's with the poly on the floor
Block moisture coming up?What's with the poly on the floor
@jetmechmarty wins the prize. Before I started to keep the garage warm, a lot of moisture would come up through the concrete. The plastic was intended to keep the moisture away from the underside of the cars. Now there’s heat (above freezing) and there’s no condensation under the plastic as there used to be. I’m putting in a dehumidifier today to see what’s in the air in there.What's with the poly on the floor
Very nice! That will keep you nice and cozy all year round! Congrats!Well, its been quite a while since I had time to post anything other than some good jokes (I really do like the paycheques - but working really is a drag). However, I do have a moment this morning - and the Great Canadian Pole Barn project reached a major milestone just yesterday!
WE HAVE HEAT!!!
The natural gas line was connected to the teeny little boiler and the system was started-up and is pumping nice hot glycol-water mix through the hundreds of feet of plastic piping buried in the concrete floor. These systems cannot change the temperature quickly due to their relatively low power and the immense thermal inertia of the concrete floor, but once the temperature is up, things stay warm and they don't use a lot of energy....as long as the structure is well-insulated.
There is 3" of styrofoam insulation below the concrete, R60 in the ceiling and the walls will be <I think>, about R40 when they're done - so it should be pretty cheap and easily to keep comfy.
NEXT STEPS: install the six big LED ceiling lights and two 60" fans for de-stratification of the air mass in the building, then insulate the walls, install the vapour barrier and interior siding and in the spring - a 2-ton / 24,000 BTU mini-split AC-heat pump unit.
We're gettin' there!
Cheers all,
Pete
No Grimly: that is the air temperature at the thermostat (49 deg. F) and the temperature set-point (55 deg. F). The system was started at about 4:00 pm and that photo was taken about 5 hours later at 9:17 pm or so. The actual water temperature is not monitored - at least as far as I know. Also the little fluid pump and the boiler are both virtually silent - at least, I haven’t heard a single sound out of the system at all.Is that the input / flow temp of the heating feed pipe?
Pete I would be very interested in knowing the temp of the liquid going into the floor.Also the little fluid pump and the boiler are both virtually silent - at least, I haven’t heard a single sound out of the system at all.
Ah, you're using those fiddly Murcan units, which surprised me.No Grimly: that is the air temperature at the thermostat (49 deg. F)
Without exaggeration I probably own 125+ screwdrivers and I keep buying more. Same for pliers, hammers, sockets, ratchets….. Do you think I have a problem?Not trying to hijack but all this talk about shops and work spaces really got me thinking. Since a few days before Christmas I’ve been in the Garage every day “remodeling”. I realized that not having a shop building was just the way it’s gonna be so I better figure out what to do with what I have. I have emptied and gone through every cabinet, shelf and toolbox and eliminated most of the clutter I’ve let happen over the years. I literally have empty cabinets and drawers in my tool boxes Now that I’ve realized I don’t need 12 Channelock pliers, many brands of screwdrivers in the same size and just any tools I’ve never used. I had way to many duplicates and more of tools. Luckily the oldest and his fiancé just bought a house so he starts out with a full standup box and plenty of power tools I took the main assembly table from the middle of the garage that was taking up most of the space, cut it in half and re-installed as a bench. I’ve pretty much gone through everything I have and reworked drawers to a point where I’m down to sorting out the junk in my organizers.View attachment 233459View attachment 233461View attachment 233458View attachment 233460
