I hope all goes well.I just though having a spare or 100 might not be a bad idea
No Ozarks for me probably a major surgery or 2 instead
Thank you for sharing.
I've got the guys and gals at the Mayo Clinic in on these adventuresI hope all goes well.
Be well Mikey.I've got the guys and gals at the Mayo Clinic in on these adventures
I'm good to go
Just missing the Ozark trip bums me out but ...
Next year
Best wishes for all to go well and a speedy recovery!I just though having a spare or 100 might not be a bad idea
Agreed; slightly rounded edges on your tools really helps, work around and around several times don't try to beat it down all in one shot. This keeps you from getting too much metal stretching. some electrical tape and a big ole hose clamp around the metal band is very helpful both taking it off and putting it back on.^Once it's back together I lay them down on a wood surface with a towel between the clock and table and then tap the edge back down. Small tack hammer with a flat drift will do it.....easy as you go. Be prepared to spend almost the same amount of time that it took you to undo it.
Thank you both for your help, I was concerned about creasing the bezel when I fold it back down on a sheet of timber with rubber on top to avoid scratches to the face.Agreed; slightly rounded edges on your tools really helps, work around and around several times don't try to beat it down all in one shot. This keeps you from getting too much metal stretching. some electrical tape and a big ole hose clamp around the metal band is very helpful both taking it off and putting it back on.
I got all fancy with an aluminum fixture but the hose clamp does the job too.
View attachment 237933View attachment 237934View attachment 237935View attachment 237937
I don't show it but some sort of drift, again with rounded edges, grind it up out of an old bolt would work fine, help bending it back down smoothly.
Those look very good!Sent out my spare wheel for powder coating. went with a bronze and gloss clear
