Good eyesPretty clean looking fab on this license bracket??
Looks like a 1950 Pontiac tail light.
Thanks, I will revisit that supplied hardware.If supplied with the mufflers, do use the sliding track insert ......
If you just put the bolt heads in the track, they won't hold long (they'll bust out of it). If you didn't get these tapped slide track bars, I recommend you make some.
Started fitting the Commandos today. Curiously the fitting is different from @Ben1 experience. My best fit is using muff brackets from the stock system (I assume stock system). Since those brackets have lots of years (rust) on them I will get out the mini grinder and coarse rol lock pads then shoot them in rustoleum black. Side note, one seems to have a shipping ding but I can orient it to face down and in so only I (and you) will know it exists.View attachment 245130
Only a couple... maybe 4 spot welds. Just drill the bracket off. Iffn you drill all the way through the bucket, call 'em "drain holes."So I am seeing a major oversight on my part. I never intended to have a headlight aiming bracket and that item never reared it's ugly head until I fitted the shell to the new mounts. Do I leave it hanging out in the breeze or figure a neat way to cut it off with out damaging the stunning "Paint by Jim" finish?
Thanks JP but the shell rides much lower than stock, I am seeking a cleaner look AND I have had a rum or 3 after sunset so nighttime riding is out. The next owner can sort it out...
Vibrate? Really?Due to the way these bikes vibrate, I'm not sure just the two bolts into the sides of the bucket will be enough to hold it where you want it pointing for long. I think that may be why Yamaha put that stay on there.
..and I choose "Candy Apple Red" sharpie to cover the bare metal?Only a couple... maybe 4 spot welds. Just drill the bracket off. Iffn you drill all the way through the bucket, call 'em "drain holes."
you're right there 5T. My non standard non-retained headlight needs readjusting after every third ride, however tight I bolt it up with thread lock.Due to the way these bikes vibrate, I'm not sure just the two bolts into the sides of the bucket will be enough to hold it where you want it pointing for long. I think that may be why Yamaha put that stay on there.
And it never ends... I did a preliminary set of the exhaust. The P-clamps that mount the head pipes to the frame need 1/4"- 3/8" spacers to keep the muffs outside the axle nut. Shouldered bolts are the hot ticket for pushing the clamp together. 12mm bolts and a washer or 2 make a cheap spacer.View attachment 245144
