https://www.georgefixs.com/new-74-7...ers-intake-manifold-boots-gaskets-bs38-carbs/That does sound like an air leak in front of the carbs or maybe fuel starvation ? Idk.. it’s a 2 stroke thing..
No barbs, but OE quality.
There was a Canadian Gentleman A week ago or so here -- .Tightening the intake Clamps and Flanges against cylinder .getting rid of air leaks getting rid of thisFixed the electrical issue.
Now back to getting it to run right.
When I first start it after it has sat for a bit and cooled off, the rpm’s run around where they should at idle. 1000-1200.
After it gets warmed up, the rpm’s take off. Like a run away diesel. The rpm’s run around 3500-4000 and the whole bike vibrates across the floor on the middle stand.
I can put down slightly on the throttle rod and it brings the rpm’s back down to 1300ish.
As soon as I let up on the throttle mechanism the rpm’s shoot back up. I’ve tried giving it a little throttle at the grip to see if the rpm’s would spike and come back down but they don’t. They just stay high.
I’m thinking the butterfly’s need adjust?
Isopropyl seems to be a good "wipe down" prior to "rattle can" touch up spraying. It leaves no residue that I know of and cuts petroleum residues of mineral spirits and other solvents.View attachment 333225
Isopropyl Alcohol is always on hand at my home. That cleans many things well including carburetor bodies and brass components with Q tips or brush. Cheap! So many uses.
How would you suggest setting the rpm’s on the start up then? Just wait until it gets hot and then set it to 1200? Once it’s hot, and I adjust the rpm’s down to 1200 it stalls. I’m not sure how to keep it running at that point.That 1200 RPM idle spec is for a hot engine. If you set it at that on a cold engine, once it warms up, the idle speed will begin to climb. Once it gets to 1500 or 1800, the ignition will start advancing, and that will increase the idle speed even more. This is a "self feeding" problem. As the ignition advances, the RPMs climb, which causes more ignition advance, and more RPM increase. The bike can end up at 3K RPM without you even touching the throttle.
Thank you.When the bike is warm is when you want to adjust the mixing screws.
This is helpful. Thanks.You have to kinda "nurse" it along with throttle blips to keep it running while it's still cold. The idle speed will be lower, and maybe too low for it to keep running on it's own. Finding the perfect idle speed setting may take some tinkering. You want it slow enough so hot, it won't start into the advance curve but cold it will still be fast enough to run.
That being said, your carbs may need some additional tuning. Are your float heights correct? If the fuel level is too low in the bowls, the bike can stall while idling.
"Checking fork tubes goes on your list. It's a worthy project you have if you're into it."Checking fork tubes goes on your list. It's a worthy project you have if you're into it.
I met a young rider on the Natchez Trace last year. He was on a weekend journey on an RE Interceptor. Both my bike and his were carrying a weekend's luggage. He told me I was riding the real deal and his bike a fake. He offered a trade right then and there. Tempting, but I wasn't about to take advantage of his ignorance.View attachment 333844View attachment 333845
The XS650 currently fits in a popular niche.
Yes, one float was right on spec. The other was slightly twisted. One bulb was at spec, the other was 1mm higher. I wasn’t comfortable trying to twist it so they were even.The float height spec usually has a "+/-" factor attached, in your case +/- 1mm. That would mean that anywhere from 24 to 26mm is acceptable. However, I've experimented with them set to the limits and find the bike seems happiest at the spec. Also, when setting them, you need to measure both sides or bulbs. The floats are often twisted on their bracket and one side sits higher or lower than the other. You won't catch that unless you check both sides. And if they are off side to side, the level you set on one side may not be what the actual level ends up being.
Melnic, you should eventually be able to find one setting that works both hot and cold, and not need to go through all that adjusting as the bike warms up. Granted, you may need to keep it running when cold with some throttle blips, until it warms enough to idle on it's own. I do have to "tweak" my setting a couple times during the season it seems, turning it up a little when it's colder out and back down a little when the weather gets hot.
When I first got my 650, I thought that 1200 idle sounded a little "busy" or fast, so I turned it down to around 1000. But then the bike would randomly stall at stops, so it seems it really needs that 1100 to 1200 idle speed. I've gotten used to it and it sounds normal to me now.
That would also make sense as to why I have had a bike that I could leave the petcock on and never spill a drop while another bike would pee a little gas on the floor to remind you to shut it off.Yes, it's a rather common issue and easy to remedy. Remove the float, grab both bulbs, and gently twist them in the direction they need to go.
VM34s will idle nicely down arround 800-900 rpm when warm but I set them higher so the cold idle doesn't randomly die. There is no charging at these low rims but I ride very little in places I may need to idle for more than 30 sec or a minute. YRMVThe float height spec usually has a "+/-" factor attached, in your case +/- 1mm. That would mean that anywhere from 24 to 26mm is acceptable. However, I've experimented with them set to the limits and find the bike seems happiest at the spec. Also, when setting them, you need to measure both sides or bulbs. The floats are often twisted on their bracket and one side sits higher or lower than the other. You won't catch that unless you check both sides. And if they are off side to side, the level you set on one side may not be what the actual level ends up being.
