How to Polish Your Valve Covers
leggers
Thought I'd share my video on polishing valve covers.
keep in mind that you can always start at a lower or higher grit depending on the level of scratches that are already on the surface of the metal. Likewise don't be afraid to try out different buffing compounds on the wheel.
Enjoy.
Good simple how to video! :thumbsup:
I like to wet sand the whole way through. I find it makes my paper last a lot longer. Just some water and simple dish soap dip the paper in, cleans all the debris out of the grit.
This is a good suggestion, and I have gone through this process wet, but I like the way the dry paper bites the metal. But yes, keeps the dust down a lot!:D thanks!
I like to start with paint stripper and then black (coarse) buffing compound on the coarse buffing wheel, switch to white on the soft wheel done, no paper needed. A set of 4 takes about 1/2 hour. I have a Harbor Fright 3/4 buffer and it's the bomb for some buffing. I want to go up to a bigger buffer but am waiting for a "deal". Various grades of coumpound work but you need to keep wheels and compounds separate. Great video! I prefer a full face shield when using the buffing wheel, the compound filled cotton fluff the wheel sheds are not good for eyes OR lungs.
Thanks Gary. Good points here too, I have a plexi shield on my bench wheel, but if I was using a dotco wheel I would definitely suggest some sort of eye protection. I'll have to try getting the black compound, I'm sure that saves a lot of time.
I just bought a Caswell 3/4 HP buffer. It should be here tomorrow. But I use my hand buffer ( Dewalt 9'' ) all the time on restaurant equipment so I know how dirty an area can get around buffing. I'd like to put something on the wall behind my buffer that I can clean. Otherwise I'll end up with a ton of buffing compound on the dry wall in my garage. I thought about a clear shower curtain then I could just take it down and throw it away every once in awhile. But I wondered if anyone has a better idea?
Thanks
Jack
So how do I set this up so it's a really easy clean up. And of course I don't mean every day but say every few months or so? There has to be a way? Especially with as many bright minds as then forum has on it.
Jack
I like the shower curtain idea. I was lazy and just built a cardboard "enclosure" with some duct tape at the end of the bench that catches most of the residue.
The rest just floats around the shop until it settles on.... everything..:rolleyes:
Oh, and wet sanding is superior to dry, imho.
And good wheels really help. The HF wheels aren't so good.
Well I'll try the shower curtain thing for now. And my wheels are from Caswell so they should be ok. I'll build a fixture to hang the curtain from tomorrow and go buy a curtain. It'll look pretty geeky but as long as it does the job I guess. Maybe someone else will come up with a better idea. Thanks for your input cycleranger.
Thanks
Jack
Hi Jack,
taping up a shower curtain (or builder's plastic) behind the buffer and changing it as required is just about perfect. I wish I'd thought of doing that instead of stapling 32 ga aluminum flashing behind mine and swabbing it clean with solvent now and then.
But what gets to me is the airborne particulates that come off the buffing mop.
I was perhaps two minutes into my very first polishing job before I stopped to add a breathing mask to my protective gear.
If I was going to polish more stuff than a small cover plate every few months I'd get me a big old dust collection intake and extractor fan.
Found that "deal" and upgraded to a 1 1/2HP 3 phase buffer 5 years ago. It's out in the shed on a VFD so single phase 220 runs it. variable speed is a VERY nice feature to have.
The smaller VFD drives a 1/2HP belt drive buffer under it.
Also have a 1/2 HP belt drive buffer in the shop for all those "little parts" bolt heads, etc..
Motto; Too much is not quite enough.
