Make Offer - 1971 Yamaha XS1-B XS650
Price
6888
Lawrenceville, GA
Lawrenceville, GA
Just finished rebuilding my 1971 XS1-B.
https://atlanta.craigslist.org/atl/mcy/d/lawrenceville-1971-yamaha-xs650-xs1b/7923437219.html
You looking at a rebuilt 1971 Yamaha XS1-B XS650. This was a frame off rebuild. Front and rear spokes were replaced. The frame was repainted alongside all the tins. The engine was rebuilt, valve job and seals replaced, cylinder honed, new rings installed and cam chain replaced. All the parts listed below were replaced or rebuilt. The tank was coated with Caswell gas tank epoxy. The headers and mufflers were replaced. This year is getting very hard to find in this condition. Fork tubes were replaced with new seals. All cables were replaced. The list is very long. Frame and engine numbers match. The bike runs and shifts great. Clean Ohio Title.
1971 Yamaha XS650 XS1B Video
Below is what I replaced.
Muffler Set - OEM Replica - 25 1/4 inch - TX650 - XS1 - XS1B - XS2 #07-0652
New Seat
Frank's Fork Tubes
Headpipe Set
House of Kolor Pagan Gold Candy Basecoat 12-Ounce Aerosol Spray Can (2)
70-73 Chain Guard Chrome Plated by Electroplating of El Paso (Show Chrome)
YAMAHA XS1 XS1B XS2 TX650 NEW CHROME SIDECOVER TRIM
Shinko 712 Front Tire (100/90-19)
Shinko 712 Rear Tire (110/90-18)
Tank Badge -Red-65-6500 (2)
Cam Chain-BF05T XS1-XS2-102 Link #52-5003
Wire Harness (24-6570)
Yamaha XS1B Shock Set
Handlebar - Yamaha XS1 XS2 650 Reproduction #23-12548
Yamaha XS1B Handle Bar LH Switch
Ignition Coils - Single Output #24-72404
Caswell Gas Tank Sealer
Gasket Kit
1970-79 Yamaha Condenser & Contact Points Kit tune up xs1 xs2 tx650 xs650 xs 650
Spray max USC 2k High Gloss Clearcoat Aerosol (2 PACK)
Battery 12N5.5-3B + Battery Acid
Jinkum Ignition Switch
Turn Signal, 12V Amber #11-2182
Oil Filter Strainer (Sump) #15-6500
Side Cover Emblem Gold (2) 07-4661
Air Cleaners 15-0651
Yamaha XS1 XS2 TX650 XS650 Piston Ring Set STD -Set of 2 - 256-11610-00 Repro
Seat Grab Bar
Front Brake Shoes #29-6502
Gas Cap Assy 20-0650
Fork Tube Cap Set #27-4000
Clutch Friction Plate Kit Set For Yamaha TX650 XS650 XS650SE XS1 256-16331-00 US
Carb Kits 48-1917
Drive Chain Adjusters #28-1064
Yamaha TX650 TX750 XS1 XS2 XS500 XS650 Carburetor Float and Pin 256-14985-00
Rear Spoke Set #19-0050
530 X 120 Links Motorcycle Drive Chain 530-Pitch
Front Spoke Set #19-0049
Brake Shoes- Rear 29-3211
Rider Footrest Rubber Set 02-2650
Rubber Joint - For Carb to Airbox (2) 15-0671
Carburetor Adapter Interface For Yamaha XS650
Oil Filter Screen #15-6501
IRC T20063 Standard Tube - 3.50/4.00-18 - TR-4 Stem
Drain Plugs (2)
Oil Seal Kit
Muffler Clamp #07-4072
Spedo Cable #51-3321
Clutch Cable # 51-6500
Throttle Cables #51-3506
Throttle Cable #51-3507
Front Fork Seals
Perch Assy - Clutch - 7/8 inch - Silver - R5 - XS1 - XS1B - XS2
Wire - Points Harness - TX650 - XS650 - 1970-1978 #14-0777
Chrome Point Cover Screw #49-0709 (4)
Throttle Sleeve #02-2463
Chain Puller Set #28-1064
Shift Lever #19-0072
Brass Cylinder Head Washer (4) #01-0651
Lower Engine Case Screw Sets #49-0650
Brake Cable #51-6501
Rear Fender Damper
Rubber - Kickstart Pedal - 15mm Shaft - TX650 - TX750 - XS650
Spark Plugs (2) NGK 5122 BR7ES
Spark Plug Cap #23-3114
Chrome Crown Nut-Crankcase (6) 49-0248
Flasher Relay #10-1172
Bolt, Footrest #99-0679
Brake Lever
Drain Plug Crush Gasket (2) 17-3802
Brake R/S Switch 12-0009
Clutch Lever #30-26802
Brake Lever Holder Bracket Perch - Polished - 1-Piece For Yamaha 01-5101
Rubber Grips #02-2421
Side Stand Bolt #37-0007
Brake Stay Bolt Set #29-7010
K/S Rubber #02-2471
Netural Switch Rubber Cap
Cylinder Guide Bar Nut #49-0722
Battery Band #10-1177
Cylinder Guide Bar Bolt #49-0723
Auto Advance Drive Pin #14-0653
Grab Bar Bolts and washers
Similar threads
  • Price: 1500$ CAD
  • Moncton New Brunswick, Canada
Replies
4
Views
2K
Sold / Found / Inactive - 1975 XS650B
  • Price: $2000
  • Waterford MI
Replies
5
Views
1K
  • Price: $500
  • Montgomery County Maryland
Replies
1
Views
816
