Sold / Found / Inactive - 1972 Yamaha XS2 XS650 Electric starter
chandler arizona
scobman
Arizona
Im looking for a "Great condition" 1972 Yamaha xs2 xs650 Electrical starter motor.
Please let me know, thanks
I live in Chandler Arizona for shipping.
Your confirming that all the electric start motors 1972-84 are the same p/n ?
I hadnt looked it up yet.
Whether they are or not, any XS650 starter is interchangeable with another. The only difference I know of is that the power post location has moved around a little bit over time, so might require a little work on the cable from the solenoid to starter.
It looks like the old starter motor will drop straight down out of the motor without removing the motor.
Would I be correct on that?
I think it can be done but there are those on this forum that know way more about it than I do. I think if you hang on a bit, you will get some helpful info.
I do think it's not quite that straightforward, in that, you will also have to slide it to the left to allow the gear to disengage and clearance for this may be tight.
Wade is correct, all year starters will fit all year engines.
Cool, Yea I have my bike all apart, right now, except for the motor is still in the frame.
Took the bike apart to transport it.
The frame with motor still installed in it, DOES FIT inside of a 2005 Mustang if you remove the passenger seat.
I put the center stand back on it and also the front wheel, forks, triple tree/crown and handlebars so that the bike is standing on its own on the center stand.
So before putting the bike back together all of the way, I need to replace the "starter motor".
With everything, just about removed off the bike, it looks like their is a lot of clearance to drop the starter motor.
I could take the motor out of the frame and do the starter motor, but if I dont have to, thats the way Id like to go with it.
check it out
Yes, definitley do-able. I just did it last week - the manual recommends it in case you damage the terminal on the starter while extracting the ICE motor from the frame. Tipping the motor forward in the frame after undoing most of the engine mount bolts helps at the very end.
Ill record a video of me removing the starter in the next few days my friends.
I believe i can remove it with a socket and ratchet, npo "S" shaped wrench because there isnt anything in its way.
We'll see.
Sorry, I don't have a motor, but just for the record, the 1972 motor has the cable permanently attached to the motor. All other years the cable is a separate piece, attached to a post on the motor with a nut. All years interchange. If you get a 73 or later starter, you will also have to get a cable.
you may need to use an “S” shaped wrench to get to the bolts holding the starter motor !
Yes, I seem to remember that you need an offset box wrench to reach two of the bolts, but if you say you can get a socket and ratchet on all 4 bolts, then you're good. I guess maybe the offset box wrench only applies to 1974 and later frames.
That may be true about the offset box wrench for later years. ???
I was told by a very credible guy here who did 5k worth of paint work for me from his home in Wisconsin, many years ago,
he said Id need to either remove the motor or be able to maneuver the motor around in the frame to drop the electric starter motor.
So, as my picture shows there is a lot of clearance, the rear brake assembly is not installed on my bike.
The rear brake light sensor not installed. The stabilizer bar for the rear wheel isn't installed.
The side stand isnt installed either. The kick starter lever, rear brake pedal and footrests are not installed.
.....Perhaps, with all those parts not installed, maybe the starter does drop down unhindered ???
Iam able to get a socket on all 4 bolts. (1 bolt was missing already).
I can put my fingers and tips in between the frame and the back end of the starter. About 1 inch approx.
Im believing the starter motor needs to come almost all of the way straight back then drop down.
******* I should check MIKESXS for the seals and etc before I try to take it out.
And I still need to find & buy the replacement Electric starter motor.
************This is the bike in question. After replacing the cylinder jugs, pistons after the bike sat for 30 years in 2012,
the bike started on the "1st kick"
However my dad the original owner said the electric starter went out on him in 1978.
Thanks guys
XS2 in question
Similar threads
  • Price: $3,300.00
  • Dingmans Ferry PA,18328
Replies
3
Views
620
  • Price: 300.00
  • Chandler arizona
Replies
4
Views
1K
Sold / Found / Inactive - 1972 Yamaha XS2 XS650 Air Boxes
  • Price: $50.00
  • Chandler Arizona
Replies
2
Views
771
Replies
0
Views
505
