Hotrods316
Hi everyone!!!!!
Thanks for all the bits and pieces of help so far from me posting in others’ threads. Getting there.
I will make this my official introduction thread and a time piece to the process of bringing this back. Found from here it’s a cinnamon brown 74 tx650a.
Got this bike from spongebobs pineapple and been fighting all the old corrosion and PO cobbling. I’m brought things back from the
before-this one is the next.
I cleaned the carbs, acid cleaned the tank, rebuilt petcocks.
Douched the engine and got it spinning free on the kicker by hand, drained and cleaned the sump (strainer/filter mod to come).
Need to pull clutch and get the tighter starter spring. It pulls on a feather
and someone whacked the heads of the clutch screws
That’s another project for another day.
Toleranced the cam chain tensioner.
Valves look good clearance wise.
Got antsy and tried kicking, wore myself out and said okay time to do points, lol.
I’m setting points, I have static timing going well on the F mark with my points 12v light.
I have a question the points remain open for a whole 360, then 180, close and the open on the fire? This seems correct as far as a 720 degree firing cycle for standard 4 stroke, but is this correct for the xs650? I’m new to this model bike, played before on a xs400 so used to Yamaha and peculiar traits but wanted to ask the brain trust.
Also can’t find the official “spring wake up drill thread “ so don’t be afraid to say hey check this with your replies, if you’re nice you won’t hurt my feelings
Thanks pics and much much more to follow
Matt
Matt
