uksparky
Hi all...ever since i put my engine back in after rings/ tensioner job i have this ignition problem...all stock...starting cold with choke ok, idle ok revs ok. Taking out on road the engine will cut out for a second through the throttle range, it will do this about four times while under a load. Once engine is hot its perfect...past work new stator 14.3 volts charging...good spark..carbs rebuilt new boots, no vacuum leaks..wiring connectors all clean...Its almost like turning the ignition off and on...lights and guages all ok nothing goes off. I checked inside headlamp wiring all ok...like i said when the engine is hot it runs perfect.. I was thinking TCI ignition box... California XS
