1980 XS650 Special II Charging problems.
a197120
iusa
Hey guys! I have been trying to get my 1980 xs650 II that was sitting around for a while and after some routine maintenance I have it mostly figured out except the charging system being low.
For the most part I have ran up and down the harness checking connectors and using contact cleaner on connections and making sure there's no raw wires at any bends.
So far I have replaced...
  • Old glass fuses with in-line fuse holders (main fuse was getting very warm, it still is getting warm but not nearly as badly).
  • Battery.
  • Brushes are also relatively new, I replaced them last time I was trying to diag this problem a few years ago.
Headlight turns on when the bike turns over.
I've lurked around for a bit so I did some preliminary testing and just wanted to see if anyone could help me decipher my results. I think the issue is going to be the rotor because of the low resistance across the rings but if anything else looks suspect or there are other tests that people know of I would greatly appreciate the help.
testreadingnotes
Battery voltage fresh off charger13.23V
Battery voltage with key on12.45V
Slap testworks, but not very strong.
Battery voltage with starter cranking10.70V
Battery Voltage @ low idle12.50V
Battery Voltage @ 3K RPM12.88V
Battery Voltage @ 5K RPM13.00V
Grounding left brush to groundno voltage increase
Voltage @ Left Brush (not running)5.11unsure if this is supposed to have voltage??
Voltage @ Right Brush (not running)11.45
Resistance across rings2.2Ω
Ring 1 to ground0L
Ring 2 to ground0L
AC Voltage White Wire 17.5V@3K RPM
AC Voltage White Wire 27.5V@3K RPM
AC Voltage White Wire 37.5V@3K RPM
Voltage drop tests starting voltage12.24VW/ key in on position, engine not runnning
Voltage at main fuse12.12V
Voltage at brown wire @ ign. switch11.72V
Voltage at red wire @ ign. switch11.88V
Voltage at brown wire @ wiring harness11.48V
Yes, your charging output is very low, only about a half a volt, and the resistance between your slip rings is low as well. I'd say you need a new rotor. Contact Jim on the forum here about a rewind. If you're serious about keeping the bike then you might want to get a spare rotor. If you watch eBay, you can usually find one for less than $30 eventually. I've bought several and had pretty good luck (only one has been bad so far).
Check the battery voltage at the ignition key before and after the switch. They are notorious for loosing voltage. May need to dismantle and clean contacts
It drops about .16v from red to brown wire at the plug in the light box with the key turned on. Resistance with plug unhooked across is .6 ohms
Yes, I should have mentioned that, lol. You'll want to shop for an '80 or newer rotor, one that looks like this ......
The pick-up magnet is sticking out from the outer slip ring at about the 4:30 position. What you don't want is a '79 or older rotor. It has no pick-up magnet .....
There is someone local who runs an eBay parts shop. I will see if he has any in stock to save some time.
Even if it tests good, age is against it. Many a story of an original or good second hand one leaving one stranded on the side of the road. If it does work get yours rewound straight away and replace the other or carry it with you and the puller.
I wouldn't pay good money for a running one, prefer to buy a dud for nix then get it rewound.
Jim is the go to guy on here.
There are reputable rewinders about I am sure. Finding them with confidence and good reviews could take time.
  • Battery.
testreadingnotes
Ring 1 to ground0L
Ring 2 to ground0L
Send your charging rotor to @Jim for a rewind. You won’t be sorry. I have at least three of his rotors.
So I bought a new rotor and am now getting much better voltage when idling 13.0 at idle and gets close to 14 when I rev it. I drove it around for around 20 minutes yesterday and had no problems. However today I try to run it and it won't idle over 3500rpms.
After some googling I unplugged the 7 pin connector on the left side of the bike and immediately the bike will rev all the way up to 7500. Some people were saying this could be a bad tci box? Could it be the regulator? Any ideas on were to begin troubleshooting would be awesome.
It would be new from mikesxs . . I examined the 7 plug connector and it seems a little corroded/rough on the red wire. I think I may bypass the plug for this wire and see if there is any change
