1981 xs 650 for sale 1800.00
ramondaze5805
ga
i have a 1981 xs 650 hs .the frame is numbers matching ,has not been wrecked has had a top end rebuild .new cam chain ,chain guide i have all receipts from 2021 when the work was done.new non vacuum petcock .new speedometer .new rectifier/regulator,camshaft bushings.new seals on the starter motor .seal to crancase to starter.front brake master cylinder from t c bros .boyer branson ignition also tc bros.13.5 progressive magnum rear shocks.from 650 central .gas cap seal ,switch block left hand ,and switch block r hand .new ignition switch from dennis kirk.new steel front brake lines ,new num4 starter gear.all new gasket set frpm mikes x s .new rings ,and carb kit .new clutch cable ,new brass swingarm bushings.new front sprocket.oil sump oil filter strainer plate.valve seals . new diapramhs for carbs. thats most all of it .cash please only.i have pictures ill post and can provide more on request.
gggGary
Just call me squirrel brain
XS650.com Supporter
Baraboo, WI, USA
I would suggest moving to, or reposting in the classifieds, MUCH bigger audience there.
Let me know if you need help
Easy to upload pics round here.............
Oh welcome to the forum. :thumbsup:
