1981 XS650 Cafe Project tips
1981XS
Serafina, NM
1981 XS650 Café Racer Project:
I’m hoping this post will help someone with their project. During the build I ran into several problems that should have been easy to solve but weren’t. Here’s what worked for me:
Bought my 1981 XS650 Special II brand new in 1980. In 40 years it’s never been dropped, always garage kept, and in pristine condition. I started the project in 2010 and finished this week - it hasn’t always been my first priority. I'd replaced the original Keihin’s with a pair of Mikuni flat-slides - a great upgrade at the time. All else (except wear items) was original. Total miles were about 24k. A friend mentioned Café Racer Magazine, and that the XS650 was a favorite for café builds. Add my love for the look (not the reliability) of old British bikes, and I had to take the plunge.
Rule #1 was that no part of the frame would be cut or welded. The bike was in such good condition I wanted to leave the door open to restore it to original spec. I saved all original parts. The final result would have been better looking if I’d removed the numerous mounting tabs, etc., but…
I stripped as much weight as I could, omitting the center stand, starter, battery, and fenders. I replaced the wheels with lighter rims and tires, the gas tank with an aluminum tank, the rear seat with an aluminum/fiberglass seat and cowl, the handlebars with aluminum clip-ons, the original pegs with a pair of aluminum rearsets, and a lightweight drilled front brake rotor. I replaced the original exhaust system with a 2-into-1 header and a new lightweight stainless steel muffler.
Step #1 was strip the bike down to nothing and powder-coat the frame. I should have masked the serial # first, as I found out when trying to get it registered. Rookie mistake.
The original engine had always pushed a lot more exhaust pressure out one pipe than the other, even though cylinder compression was closely matched and the carbs were synched precisely, so I decided as long as I had the engine out I’d rebuild it. I ported and polished the heads, installed new rings and pistons with stock sizes. I replaced the valve seals, and glass-beaded and lapped the valves. I replaced all crank, rod and camshaft bearings, etc. I’ve used Amsoil in the engine since it had 500 miles on it, so there was no wear on anything (except the cam chain guide, which had nearly disintegrated), but as long as I had it apart I figured I should do it all. I considered a 255 degree crank conversion or punching out the engine to a 750, but elected to keep it simple. I replaced all bearings, seals, gaskets, O-Rings, etc.
Regarding suspension and chassis, I replaced all bushings and bearings, installed Tommaselli adjustable aluminum clip-on handlebars (love these), and had TAB Classics make me a fantastically beautiful aluminum Manx-style gas tank with a flush cap and a single seat/rear cowl (these were so beautiful that I scrapped my original plan to paint this bike, and instead went with an aluminum/stainless steel/black color scheme). The tank has the factory-style front mounts, but I had to fabricate a mounting system for the rear of the tank, and I installed a pair of old-style Ducati petcocks w/ ¼” outlets. I fabricated a seat from a bottom layer of 2” moderate-density foam, a top layer of 2” memory foam, and I subbed out the leather seatcover locally. I fabricated various aluminum mounting plates for the new aluminum rearsets, the taillight, and the headlight angle-adjuster. I used Race-Tech parts and pieces to rebuild the front forks and replace the rear shocks. I changed the tire and wheel sizes, using a slightly larger diameter/slightly narrower width rear wheel than stock, and a slightly smaller diameter/slightly wider front wheel than stock. I lowered the rear shock slightly to adjust the rake angle of the suspension, increasing the positive caster to make the bike a bit more stable at higher speeds (highway speeds here in NM are 75mph, which has that 650 engine working hard. I’m not anxious to experience any tank-slappers at high speed).
The original electrical system (charging and ignition) was hammered after 30 years. For controls I went with Purpose Built Moto for micro-switches and lighting. I originally bought a Hugh’s Handbuilt full ignition/charging system, but it didn’t work. After 7 years of flat-rate wrenching and working on vehicles for 50 years, specializing in electrical systems, I had a good idea what to look for, but I couldn’t get it to go. Tried to get help (or any answer at all) from HHB with no luck. Since I’d waited 2 years before installing the system, it was out of warranty. Regardless, I’m done with HHB. I changed course and ordered a Vape ignition system from Dan at RE-MX. He answered all my questions, and his answers turned out to be dead-nuts accurate. The Vape is a fantastic ignition and charging system! I also got an ultra-lightweight lithium battery to power the LED headlight/turnsignals/brake light and horn. I tried the first and fourth options for setting the advance curve on the Vape, but the fourth was a bit too "smooth". I went with the first (original) setting which gave me the kind of kick in the ass I was looking for in each gear. I had to fabricate an aluminum box to hold the new ignition and charging system components, that mounted under the seat. Spark is strong. The only hitch I had was discovering there’s quite a bit of current running through the kill switch wire (who needs coffee?), and my original plan to use a micro-style switch didn’t work. Instead, I installed a toggle switch under the seat to act as a kill switch and to discourage theft.
Once everything was together, I was still having some issues with starting and running. I started the project in PA at 400’ above sea level, but was finishing it in NM at 6,400' above sea level. Instinct told me it was a fuel issue, running too rich. I’ve always been good at jetting and setup work, but I couldn’t get the Mikuni’s reliably right. A friend recommended trying a pair of 36mm SmartCarbs. After speaking with Corey Dyess at SmartCarb, I felt confident that these would allow me to ride all around this area, from 9,000’ down to 4,000’, without having to mess with the carbs. These should also provide a major improvement in gas mileage - important as it can be a long distance between gas stations here. These were NOT cheap carbs, but they are worth the price of admission. They’re built like a brick shithouse, beautifully made, and their tech support was fantastic. Setup was straighforward, just following the directions. I prefer mixing data and instinct when doing setup, so I installed a pair of bungs in the header pipes, installed an O2 sensor, and connected a fuel/air mixture meter. The meter was small, fitting right in between the gauges, and giving me great information about the mixture in real time, during test rides. Once I had the carbs running between 10.8:1 and 12.2:1 in all conditions, I did a plug check and had exactly what I wanted to see. Then I removed the fuel/air meter and wiring. I wish all cycles came standard with these meters, but that’s just me.
The only issue I have with the new carbs is that my Motion Pro throttle assembly can’t provide the travel needed to operate the slides from idle to full WOT. I’ll contact them to come up with a solution soon.
The bike now starts with one kick, cold or hot. I’m 65 yrs. old and I don’t kick like I used to, so this was important! It runs better than it ever has – stronger pull at all throttle positions, no issues on decel, crisp off-idle response and great WOT performance. I now have to be careful not to hit the throttle too early in a corner, as I can get into trouble quickly.
I hope this can help someone else avoid chasing their tail trying to get their bike running right. If you have any questions about parts, pieces, suppliers or installation details, I’m here to help. I'll add a couple of photos soon. Best of luck!
Wow great result great write up. I enjoyed riding in New Mexico and Arizona the most on a brief visit to your country.
I completely agree with you on the Vape it is quality, and the results your experiments with the advance curve agree with what I found, that is leave it as factory set. It will be interesting to see how the lithium battery holds up.
The smart carbs have been recommended to me but they are so far out of my price range they may as well not exist.
I have been considering a O2 gauge, what brand did you opt for ?
The body work looks great unpainted and you can always paint it later if you want a change.
Thank you for posting and do you have any other photos of the build.
I understood about the SmartCarb pricing - it made me wince...hard! But I can't afford to get stranded out here, and my goal with the project was a starter-less one-kick lightweight bike. And that's what those carbs and the Vape gave me. The air/fuel meter is made by AEM. I attached photos of the gauge and the taps in the header for mounting the 02 sensor. I had to order the bolts and washers from McMaster-Carr, which also made me wince, but couldn't find those locally.
yes more pics please
detail shot of carb install?
calendar 2026 ??
Hope this gives you more detail. They fit in a stock Mikuni TM34 mount, but I had to replace one of the cap nuts on each of the valve adjuster covers with a standard nut so that the upper corner of the carb wouldn't hit the cover. There are some companies that make angled carb mounts, and one of those might be a more elegant solution in the future. Also, I had to get a pair of Mikuni cable guides to thread into the top of the carburetor and receive the cable -Throttle Cable Adjuster fits Mikuni Carburetor Cap VM + TM series Blaster Banshe . Finally, I haven't spoken with Motion Pro yet about a throttle that will give me enough range to achieve full WOT, and will do it within approx. 120 degrees of total travel. Once i have that solution I'll post info. One final note about the SmartCarbs - Plan to check the float levels. I foolishly assumed that right out of the box they should be spot-on, especially as well-packaged and solid as these carbs are. Not so much! Relatively easy to check if you follow their procedure, but it's not as easy as the Mikuni setup of straightforward measuring the float position.
If those are standard intake manifolds, they won't hold up long without the metal shrouds on them, they need them for support. If they're JBM manifolds then they should be OK, they're supposed to be stronger.
Thanks for the heads-up. I tried a pair of (nearly solid - aluminum flange w/(basically) radiator hose mounts from Dime City) but it's not working with the SmartCarbs - hose ID is much too small. The mounts I have now are still reinforced rubber, much like stock, but they're quite a bit less flimsy. Time will tell if they hold up.
Having a bit of trouble getting the engine to rev above 4k RPM. Still starting on one kick, idles great, but once it hits 4k is feels like I have a rev limiter on it. It has felt like a spark issue from day 1, but I've tried to eliminate every option I can think of.
Regarding fuel:
- I upgraded all fuel lines to full 5/16" from petcock to carb inlet, including fuel filters.
- I adjusted the float levels toward the high side of spec to make sure I'm not fuel starved.
Regarding spark:
- I've gone over the ignition and charging system grounds, and they should be perfect - they currently share one ground location with the coil ground and the battery ground, about 8" from the battery, and it's polished with no paint interference.
- I am using the Vape ignition, and made sure that there is no more than 6,500 ohm resistance from plug tip to plug tip through the coil, which is exactly on-spec.
- I have the static timing dead-on. At idle it is running at 4' BTDC, increasing to 34' BTDC at 3,000 RPM (max advance). There are supposed to be several other advance curve settings in the Vape. The stock on is the one I used for tuning, and it's supposed to start at 9' BTDC topping out at 38' at 3k RPM. There is another setting (#4) which I also tried, which should start at 4' BTDC (which matches my measurement), then increase to 34' BTDC at 2,500 RPMs and 40' BTDC at 3,500 RPMs (max advance) - the highest advance doesn't match my measurements, and there is no change to the measurements when changing between position #1 and position #4. I haven't tried the other curves as I have no intention of ever using them, but out of morbid curiosity I guess I could try them...
Other notes:
- Plugs are reading good enough that fouling or running lean doesn't appear to be a problem - not perfect, but good enough.
- There's a minor flat spot immediately off-idle.
- It pulls fairly strong up to 4k, then won't go any higher than 4,500 in 3rd, 4th or 5th regardless of how you try to nudge it. It will go to 4k or 4,500 in first or second, or on the stand, but above 4,500 in those conditions it either stops revving or it suddenly catches and will rev to redline, but it's really erratic as if the ignition is breaking up, shooting up to redline then dropping back to 5k, the tach bouncing around between those revs.
- Because it will occasionally rev to redline, albeit with light or no load, it seems that it's getting enough fuel, the 2-into-1 header and exhaust isn't smothering the engine on the exhaust side, and compression isn't the problem (?).
- I did have some concern about the compression, as it's low IMO (about 85lbs with carbs wide open and engine warm, but I only have a kick start option so it's hard to crank it enough to get a reliable compression reading. Cylinder leak test results were fine.
- Charging system is working great. All lighting, gauges, neutral switch light, horn, etc. are working fine.
Any thoughts or suggestions would be appreciated. I want to exhaust all options before I contact Vape about a control unit replacement.
I’m loving those carbs😍. Went on the smart carb website and had a peek at them. Love to have them but a pair would be worth more than my bike. lol. Great build and story. I think I see your bike in the 2026 Calendar. Congrats. I’m sure you’ll get the bugs worked out soon.
What does the AFR gauge reading when it flat spots? What colour are the spark plugs?
Try running it a short distance without those air filter on.
If you can get a hold of a twin exhaust give that a try as some 2-1's cause reversion that cause havoc.
^^^^^***this***^^^^^
Corey is amazing and I live and die by his product, I wonder if you should try one of Dustin’s beautifully crafted 2-1 intakes (I believe he has a sale on right now) and; sell one of the SmartCarbs (I would buy it). What is diameter of your exhaust? I have found that stock header pipes work the best for all around riding, you could get some beautiful Cone Engineering stainless megaphones from Dustin at Beck built fab (member on here) at the same time to create some back pressure. It sounds like a loss of intake vacuum due to exhaust reversions so as well as putting the o2 back on you could add a vacuum gauge.
Love your build!
With those carbs, I don't know .....
I share your concern, but I don't think it's fuel. Will be exploring further tomorrow, but I got it running like a bat out of hell today, between idle and 4k, with a minor low speed mixture adjustment. Still little improvement above 4k, though.
Thanks for your feedback. I removed the exhaust inserts I had in, thinking they were constricting it at WOT, but there was no improvement. I still have the stock 2-into-2 exhaust, so if fuel and spark changes don't clear this up, that's next. Also, riding it today, after making sure the grounds were perfect and making a small low speed/idle mixture adjustment, I had the bike pulling harder than it ever has - right up to 4,500 RPM. Then, in 1st, 2nd or 3rd, if I could eventually coax it to go past 4,500, it would erratically whip up to redline. Not right, not smooth, but pretty damned fast. The performance today seems to eliminate the compression concern from the equation, but had me leaning back towards something intermittent, which leans me back towards spark. But...
Also, I adjusted the low speed mixture because I was getting approx 11.5/1 throughout the range on the stand (which I thought would ideal, but I've adjusted my thinking recently). I now think I want idle to be closer to 10/1, midrange around 11/1, and high speed cruise around 11/1 but around 10/1 under load and WOT up until I get near redline.
Tomorrow's road test will include reading the plugs, possibly swapping out a richer high speed needle, and seeing what the Fuel/Ox meter tells me.
Do the carbs respond to a feedback loop from an O2 sensor? Seems a stock cam has a torque dip somewhere near that rev range. That might signal a change. I don't know the system and I am at the Bears beat my Packers at Lambeau for the first time in a decade 3rd Rum.
The O2 sensor gives an accurate reading so you can jet the carbs precisely. Best to run it on a dyno or rolling road as it could get a bit dangerous riding on the road trying to look at the AFR meter & throttle position at the same time.
this is my new project bike thank you for the tips page shall try to not mess it up too much
have some questions with the wiring for yous down the line as id like to redo it with a motogadeget m.unit and I dont know if i should change from a points system which i believe is still in it atm but i would like to do the wiring all at once so im not chopping and changing it down the line any advice and help is greatly appriciated.
