bclep
XS650 New Member
1981 Yamaha XS650 Special II
Best offer sale, no trades. Venmo/Zelle, Bitcoin, or cash to be exchanged at a bank to verify funds.
<$6000 total miles, restored at 5746 miles.
Everything is custom, new, professionally upgraded and/or rebuilt within the last few years. The bike is in excellent condition and starts right up. This motorcycle is a one-of-a-kind raw experience. (Way more $ into her than I will ever get back out.)
Includes clean title, barely used Biltwell helmet (XXL), uninstalled exhaust pipe baffles, original manual, original gauges, some spare parts (gaskets, passenger pegs, etc).
Partial list:
Frame stripped & all fabrication work completed
Tank color is matte white Pearl and frame is a gloss gold Pearl
Custom brass emblems, velocity stacks, LED brake light & plate mount, chain, pegs, etc.
Custom drag pipes
Fit new rear suspension
All new electronic mounts & fit to frame
Frame, swingarm, wheels etc all powder coated
Engine rebuilt, replaced all engine seals & gaskets
Soda blast & steam clean the engine
Engine prepped & painted
Cleaned carburetors, new jets & filters, jetted correctly and balanced
Ultimate high output coil & wires
New Firestone Deluxe Champion tires fitted with new aftermarket wheels
Rolling chassis built all bearings cleaned re-greased or changed
Bigfoot gear lever
New fork seals
New headlight & mount fitted
Brake caliper & drum refurbished
New brake master cylinder & new brake line
New handlebars fitting
New clutch lever & cable
New throttle body & grips
Custom plate mount & fit led tail light
New brass chain & refinished sprockets
XS tank chemically stripped then finished
New fuel taps, pipework & clips
Custom steel seat pan then covered in leather
Needs this season: Annual brake fluid change. Annual bolt torque check. Oil change. Something in the headlamp handlebar switch is loose for the low beam, may need new switch component or adjustment?
Partial list:
Custom drag pipes
Bigfoot gear lever
New fork seals
