Bike looks great against the industiral doors.
I think you need a period lid to go with the bike & gloves Raymond.....
Funny they would call them a "bacon slicer". All the industrial bacon slicers I was around the blades were anything but round. Can't think of the name of the shape of them. Now baloney slicers the blade was round sometimes.I wuz told as an impressionable kid the bacon slicers were supposed to enhance a bikes front brake by adding cooling surface to aid heat dissipation.
When I were a kid, folk used to buy fresh sliced bacon and you would see the shop assistant using the sharp rotating circular blade to cut it for them.Funny they would call them a "bacon slicer". All the industrial bacon slicers I was around the blades were anything but round. Can't think of the name of the shape of them. Now baloney slicers the blade was round sometimes.![]()
To me that's a toy. I worked on slicers similar to this. Ones I worked on did 800 slices a minuet. Now I see they are up to 2000. At the plant I worked at they sliced 1 million lbs of bacon a week. I've been gone from there over 15 years I'm sure they do way more than that now.When I were a kid, folk used to buy fresh sliced bacon and you would see the shop assistant using the sharp rotating circular blade to cut it for them.
Weather getting colder and not sure if I have seen the first signs of salt. But it was a warm and sunny afternoon so I gave the Bullet a wash before putting away.
Thank you, Bob! Pity that's not how it works with weather, thought appreciated thoSounds like a beautiful ride Raymond.
Going to be 111 degrees here today ( 44 Celsius) Would you like me to send a little heat your way?![]()
Slice's, dices and dances too, the MinuetTo me that's a toy. I worked on slicers similar to this. Ones I worked on did 800 slices a minuet.
You could get a nice diesel heater for that lovely workshop Raymond?Getting late in the year, salt on the roads, time to have a look at the Bullet's gearbox.
Step One, take bikes out from garage. Not a scene that is often, uhm, seen.
But a necessary step to make enough space to move stuff around in there.
That's better, enough room to swing a cat now. As we say in Britain. After sweeping the leaves out, will decide where the bike lift can best be sat to allow work on the Bullet from all sides while also leaving enough space to put the other bikes back in. Maybe the Interceptor should go where the bike lift sits now? Uhm, no, that will block access to the shelves . . .
On reflection, not one of the worst problems in life to face.
Plan now is take primary oil out of the Bullet, shove it on the lift, dismantle the gearbox. Don't know what I'm up to, weather going to be cold for the next few months, this could take a while.
Gearbox outer cover removed.
