Amazing what they will do to shave some weight and ££££ off the machine!Progress continues. With the primary drive outa the way, good time to assess the final drive.
First oddity is that the chain has 95 pins. Yup. 47 links plus one of them half-links. The sprockets are standard sizes at 17 teeth front and 38 rear so no clear reason why the half-link. Perhaps that is standard?
Washed the chain and gave it a closer look - not happy, and the sprockets are slightly hooked, so ordered a new set. The rear sprocket is one of those typical British brake drum/sprocket affairs with its own bearing, which I knocked out.
To take a closer look at the bearing
What look like gaps between the balls are in fact gaps between the balls. There's only ten and clearly room for a few more. Glad I investigated and makes me wonder about the quality of parts originally fitted. That comment applies to the tired chain and sprockets too.
Think I'll go have a look at the rear wheel bearings now.
Good find tho Raymond if a little disappointing.
