Followed the plan, which kind of came together. Don't enjoy doing things in the wrong order - leads to frustration, or complicated work rounds or having to un-do and re-do jobs. First, fitted the clutch centre nut, rebuilt the clutch, tempo rarely fitted the gearchange mech, used mole grips on the square shift shaft and confirmed the gears change, haven't tried 'em all yet but at least I feel happier that all the g'box bits must be in at least an approximation of the correct arrangement.
With bike in first, able to stomp on the rear brake while brandishing a 1" socket and extension tube in the direction of the rotor nut - it's tight now - and as Jim predicted the clearance is better. Still can't move a 6 thou feeler freely around the whole gap, there are tight spots which will be the fixed magnets (?) but the feeler goes in at all opposite sides so I fink it's reasonably centred.
Rotor nut tight, clutch rebuilt, the only remaining thing was to fully tighten the alternator and pass its wires out towards the rec/reg.
OMG! Dun it before and it's always a Right Royal PITA. There's a hole in the inner chain-case cover, with a rubber grommet to protect the wires. About 20mm long and with, ooh, mebbe 6-7mm hole down the middle. And the hole exits facing the vertical side of the crankcase with a gap just about big enough to get a finger into. Ahem. Cannot get two bullet connectors into the hole in the grommet so you get one through and then
really struggle to get the second through, with judicious use of curved pliers to try and pull one end while pushing from the other side. And that's before you get to the thickest part when the protecting sleeve has to go through as well bu
t absolutely will not. This already reads too much like a badly-penned sex manual so I'll give up and just say it took hours, enhanced swearing, some imagination and several changes of approach but finally got the alternator hooked up.
So with nothing else I really need to do in there, slapped the primary cover back on.
That's better, starting look more itself.
And for a laff, here's the loosely fitted change mech complete with
uber stylish gear-change lever - they'll all want one.
Starting to believe I might get to the finish line with this self-inflicted job.
