Got some updates on the bike over the past 7-8 months. You how these things go between work and other obligations.
Carbs:
Carbs are Mikuni BS38CV. Was able to clean and rebuild the stock carbs. Used a homemade soda blaster compliments of my dad to blast the fuel grime from the carbs, and then extensively cleaned them. I used a rebuild kit and replaced the floats.
I set the points to 14mm. I rigged a simple timing light using a 12v led light connected to some alligator clips. Grounded the negative side to the engine fins and the other side attached to the point. Worked well when turning the engine over.
After some trial and error was able to get the bike to idle appropriately without any misfires. (Once I realized I needed to adjust the cam chain tensioner prior to setting the timing most woes went away).
Was able to get the bike running and idling after 30+ years. Pretty proud of myself for getting it to even run considering I am inexperienced. Was able to put it in fear and putt around the driveway.
More posts to follow regarding brakes, and more...
(carbs disassembled)
(setting float height. Yes, floats height is set from carb surface w/out gasket).
(new diaphragm attached)
Carbs:
- Also, I replaced the diaphragms (big shout out to Paul @ JBM Industries. I found JBM Industries while lurking around the forum here and it was worth it. Previous diaphragms were shot. I followed their directions to measure the outer diameter of the carb diaphragm edge and placed an order using 76mm as reference diameter).
- Assembled and mounted UNI pod filters (I didn't change the jet size, although I probably should have).
- Replaced intake manifold holders. I don't have the size I ordered immediately on hand, but I can find with a bit of research. They were very tight to mount the carbs back on. Used a little heat assistance from a hair blow-dryer, a finger rub of wd-40, and some elbow grease and got it mounted. Saved a tremendous amount of back strain using a little heat.
