277 ignition
Oprahands
Missouri
Since pamco pete is no longer in the game, i was wondering if anybody else.knows how/where to get an ignition that would work with a 277 rephase
Looks like that’s going to be cam driven and ignition only. If you need a full system with new charging parts and crank driven iggy, (more accurate, stable, timing does not change with cam chain wear, parts stay cooler as nothing is screwed down to the head) Vape/Powerdynamo system is pretty nice. Does not require battery power to run ignition. Kinda like a dirt bike style magneto + a PMA and reg/rec to charge battery or run lights. More $ tho.
I got mine through Gary at Hoos Racing.
Yes it charges the battery too. PMA with a reg/rec included.
If you are doing a 277...gotta look at the clearance of the lower ignition sensor against the stock cover.
I had to hog mine out a little.
Any news on a 277 replacement ignition?
My pamcopete electronic ignition started misfiring when it warms up. Maybe I could repair it???....Has anyone tested/repaired the Pamco circuit board?
