I took the front shocks apart to clean and reseal. I found these two 2" spacers between the damper rod and main spring. Even odd, one side had the 2" spacer between the main spring and the top cap screw. It seems that this would just make the spring stiffer and has nothing to do with lowering.
Also, I do not show the 1/4" spacer that is one the damper rod. Is this factory item or did someone try some other modification.
Any thoughts?
Any thoughts?
