As long as the slide, and slide bore are OK you should do fine.
Lack of rubber mounting and vibration caused rapid wear on the slide allowing air around the slide, the second thing is often guys would over tighten the mounting flange which would distort the carb body and cause the slide to stick.
As carbs go Amals are about as basic and simple as you can get
