Hmm. Suggest treading carefully here. Tytronic seem to have disappeared?
Rawhide are made in the USA and make well known kits for Harley’s. Tytronic are Chinese made and sold as far as I know. MikesXS electronic ignition I hear mixed things on and they don’t seem to make it anymore. Rawhide seems like the best bet, but if it doesn’t work I’m out $350. I just want to narrow my problem down. Very strange that 2 carbs would develop an identical bog out of the blue after running good for so long, and replacing them results are the same.Hmm. Suggest treading carefully here. Tytronic seem to have disappeared?
way too many stock advance springs have been replaced with inferior aftermarket parts because of faulty "static" testing. The gold standard for spring (advance) action is a timing light. The advance rod/cam bore also need to be removed, cleaned, lightly lubed as an "occasional" maintenance item.I have not tested timing while engine running yet, I will do that when it gets above 0 degrees here. I have done everything else you mentioned though including replacing the advance springs. The new ones are much tighter and have the proper snap back I see in member videos here. I could try cutting a coil off the stock ones I took off that were too loose and see what that does. The reason I replaced them was I had a lingering idle and the replacement springs fixed that problem.
Do you have anything useful to add?
Try a timing light while the engine is spinning and key on.Do you have anything useful to add?
That is what I did, engine off, key on, turning the engine with a wrench. Timing was perfect. I will try with the engine running and warmed up next time.Try a timing light while the engine is spinning and key on.
That was your first step. I will go from there.
cliff
Engine running-fast idle or so..That is what I did, engine off, key on, turning the engine with a wrench. Timing was perfect. I will try with the engine running and warmed up next time.
Yes I have points, and confirmed the gap and power going to them.Engine running-fast idle or so..
Turning with a wrench?-no
Points?
OKYes I have points, and confirmed the gap and power going to them.
Yes and yes, I will check with a light when I can.We are speaking of
When we say timing light.
Static timing with a lightbulb is a great way to start, but engine running, checking with one of these is best for confirming advance timing, correct action of the springs etc.
Did you remove and clean re-lube the advance rod?
Do you have TDC marked on your rotor?
Sorry if you've already done this, (I didn't find mention of it in the thread), but as you are unable to get the points plate to line up have you checked that the timing chain is adjusted correctly? If the timing chain is badly worn or incorrectly adjusted you won't be able to align the points plate fully, exactly as you describe.update: checked timing with a light and it was off, thanks AUTOMAN. My problem now is I maxed out my adjustment on the plate and it is still firing ahead of the mark. I won’t get the chance to use the light again until next weekend so please any suggestions of what I can do in the meantime.
To clarify further, timing marks on the PMA are just to the left (1/4 inch) of the fire mark, and the points plate has been rotated as far as it can go to the left bringing the marks 1/4 inch apart. It started about 1/2 inch to the left when I first timed it.
The limited adjustment did yield an improvement riding though, so I feel like I am on the right track thanks again to AUTOMAN and gggGary.
