Wow... never heard of 'em. Just had a look and it looks like a good source to me. Bookmarked. Thanks bud!!A good source for RD parts is Economy Cycle.
economycycle.com
Um... yeah. This is turning into quiet the mystery. This pallet of bits came with 2 complete (subjectively...Jim - do your VM28's have one choke, a choke tube and are the NJ's primary or bleed type? Also, are the carb tops regular or "high top"? I'm getting a suspicion that there were different VM28's around (don't know what's OEM and what's aftermarket genuine Mikuni)
Choke tower is undrilled and has the crossover barb.... makes it the right carb. Here's both right's... side by side.Can't tell from pic. Does the black one have the choke plunger blocked and have a fitting for a choke tube? Maybe pics of the top for it?
IIRC there were OEM VM28's they referred to as "small body"
After Cerakote back to black - have high tops - choke tube fitting at right of left carb
I'd venture a guess that the black carb is (was) an OEM "small body" VM28 and the polished one's an OEM "regular" spigot-mount. The issue then becomes the NJ; do the regular take a Series 175? I've tried 175's in my "small body" and they fit, but don't run worth shit below half throttle - the small body need Series 169. Maybe you need a bleed type 175 in those (maybe regular) polished VM28's
Yep.... post #109.Like I said before, stock RD needle jets are
Did you see my edit/ added comment about the Autolube nipple? Post #132Yep.... post #109.![]()
Yep. Got it.Did you see my edit/ added comment about the Autolube nipple? Post #132
Well, those were Primary type NJ's. Does they have a # ?
169 O-0Well, those were Primary type NJ's. Does they have a # ?
