REPETE
Hello All
After nearly two years of trouble free smiling miles on the 650B many of you helped guide me through from a non running (23yrs.) bike to my favorite ride I now find myself in need of assistance again.
Please bare with me on this. I do try to be as self sufficient as possible before I ask, but my searches on the forum seem to torn up mostly information for 1980+ or bikes with PMA's and info. on removing the rotor - which I cannot determine is necessary or not.
Here's the background:
Working on the belief that my stator is bad, I began removing it last night. It was late and I stopped at that pesky little bolt tucked away where I circled in the picture. I didn't see that right away and was tugging away on the plate that protects the harness
But, the stator is apart and I'm not sure what my next steps should be.
Thank you!
- charging system suddenly stopped working
- brushes are basically new... have maybe 1500 mile on them. I removed & examined for obvious damage or wear - there was none and they were reinstalled.
- quick test indicates that about 9-10.5 amp output that would increase to high 11's above 4k rpm
- rather than play around with 46yr old rectifier and voltage regulator I bought a solid state combination unit - an ES350 something or other that I found recommended here on the forum.
- hooked it up and no improvement
- ran tests on wiring from stator to old rectifier per instructions in Clymer Manual.
- identified the 3 white wires from the stator as #'s 1, 2 & 3 and then tested them in combinations with each other. results were: 1 to 2 = .7 ohm 1 to 3 = OL 2 to 3 = OL I believe this indicates a short / grounding situation in wire #2.
- next test directed testing each white wire with one test lead on the wire's end and the other on the stator housing. results were: #1 = .282 ohm #2 = .281 ohm #3 = OL instructions read that if any of the readings is anything other than OL (infinity) the stator is bad.
- does the rotor come into play here at all? i.e. should I be planning on removing it for purposes of rebuilding or replacing the stator?
- what am I looking for in the stator other than an obvious broken copper wire?
- are there anymore tests I should perform once it's removed or start looking into having it rebuilt or replaced?
- are either the stator or the rotor supposed to be magnetized? I thought they would be, but they aren't.
Thank you!
