Vivianthebarbarian
Finally got back to the bike after a busy week. I set the gap on the points (had to run to town to get a replacement screw as one was so chewed up it was unusable). They didn't seem far off. Then I went to set the ignition timing. Turned motor so R cylinder was on compression stroke and hooked a light on the top set of points and the other leg to ground. Turn on ignition and the light comes on. ok, so i turn engine with a wrench but the light stays on....even if I go all the way around. Now I'm confused. Does anyone know what this means? I mean most likely it means I screwed up somewhere...but could it mean I found something that is broken?
