Zmccleary7
"Not all those who wander are lost" J.R.R Tolkien
The starter draws about 50A, so about any solenoid that's rated for 50A or higher will work.
Yes sir
Do a google search... there's millions of 'em out there.
99% of what's out there is rated well in excess of 50A
Yes sirany specific links you have? You seem to be the master of hard to find websites with a goldmine inventory
But, have you checked to see if you still even have a starter motor installed in the bike? Some guys remove them when going kick only.
Here is a tip.
Get a part # to use in a search
Use partzilla or any other Yamaha parts supplier or down load a parts manual from
https://thexscafedotcom.wordpress.com/
Scroll down the left side till you get to manuals
https://biker.net/
Again scroll down left hand side
https://www.xs650.com/threads/xs650...-other-information-including-xs750-850.30569/
Not just an ID thread. Links to tutorials and common information for those things needed to fix for rebuilds
Yes sirA simple look at the bottom of the motor will tell you if the starter motor is still installed. If it is, it will be plainly visible behind the rear oil drain plug ......
I can no longer muster more than a couple of kicks these days, so for me a functioning electric start is essential. If you are thinking of refitting an electric start, next thing I would do is to check that the starter cross shaft and gears are still in place. Sometimes they're removed on a kick start only motor. It would be a big job to refit electric start if the cross shaft has been removed from the engine.So it seems I do not have the starter motor.__. Now this isnāt EXACTLYYYYY a problem, I donāt mind having a kick start only, actually its kinda preferred but with the Dyna III being present (and seems to be one of the better ignitions available at the time) it seems like a waste to not have an electric start.
Thoughts? Opinions?
Part number 10 and associated other parts, gears etc -
That's a simple diagram for a bike with a PMA system. The bit I think you're referring to on that diagram is the rectifier/regulator.Upon sleeping on it and mentally rationalizing Iāve decided that no I will not be reinstalling the electric start. In my young spry youth Iām sure the kick will benefit the health(or kill my legs earlier in life) so ill stick with just that. Plus weight loss=speed
Iām liking the look of the simplified wiring diagrams makes everything light and compact. Might be a obvious answer but to the left of the coils in the diagram, Im correct in guessing thats the ignition module(normally points but now electric)?
Yes, that's the ignition system driving the coil.And of course I donāt my lefts and rights.
I meant to the right of the coils![]()
I do plan on buying the PMA kit from TCbros thats comes with the regulator rectifier, everything Iāve read tells me it'll work just fine with my dyna.
What is wrong with the charging system on the bike??
