79 xs750 carb help
WhollyDivergent
Michigan
Hey y'all I'm brand new to the scene and I'm having issues I bought a 79 xs750 everything looks fine except for the carbs I'm missing a part of the choke assembly but I don't know the part if it's worth sourcing and rebuilding or easier to buy a new set all together any help would be greatly appreciated
Here's the carbs themselves
79, i think should have these on it. Get the part no for a seach through Fleecebay or you might get lucky with a Yamaha dealer. Couldn't see in your pics where the enricher/starter lever goes
  • 78_carbs.pdf
There are chokes that are mounted vertical to the carb and operated by an up/down lever on the far left carb and there are chokes that are mounted horizontal to the carb body that are activated by sliding left to right, either by a cable actuated at the left handlebar switch OR by a pull/push knob located on the farthest left carb. Your carbs have the horizontal chokes that are linked by that long rod. On that rod there are detentes for each carb to affix a screw held clamp so they all work in unison when activated. Seems you are missing a clamp or two. Whether the three chokes are actuated by a single knob affixed to the end of that rod at the left carb or by a cable remains to be seen.....probably a knob.
Looking at the second pic, far left carb, you can see the detente. The clamp and holding screw just need to be moved so the end of the clamps mounting screw goes into that detente. Can't see the middle carbs choke clamp. You might have all you need there to put these right save for the knob.
More pics
In your third pic above, just posted, you can see the far right clamp and it's fork engaged into the choke and holding it in the choke position.
Duplicate the way that is to the other two carbs . I can see the one to the far left carb is off. Can't tell the middle due to it being behind the throttle cable holder.
