79F Ignition coils mounting plate
Leslie
XS650 Junkie
XS650.com Supporter
Sherwood North Nottinghamshire UK
Hi has any one got access to their frame, in particular I require the dimensions of the ignition coils plate, as per attached
This is a '79 Special II. It's awkward to get at it at the moment, so the measurements are close.
Front to back 8 cm
Widest point 9.5 cm
Narrow space in the middle is 7 cm
That should get your coils mounted. If you look closely, I think you can see it's made of three pieces.
Front to back 8 cm
Widest point 9.5 cm
I Have after market coils, so will use the pcd from them, the photo and dims have helped a lot, I always remember a saying from my apprentice days "Measure Twice Cut Once"
