Excellent opportunity to take out the spark plugs ground them to the cylinder head
Kick it or e- start watch how the spark Looks
Ok so I’ve done what you’ve said and the pin on the points side is at 12:00 and marks looks spot on.Though I’m chiming in here late, I did go back and skim most of the thread. You have certainly done a bunch, some multiple times, to correct the issue. I commend your perseverance.
I did see cam timing discussed briefly, but didn’t see definitive verification thereof – perhaps I missed it. Some of your symptoms are consistent with bad cam timing and this motor will run when surprisingly out-of-time, but it won’t run right at all rpm’s.
Risking redundancy, here goes:
Remove stator & tappet covers,
Rotate crank normal direction while observing left intake valve,
Rotate until intake valve opens and then closes,
Shortly after closing that valve, continue rotation to next TDC of left piston (TDC compression stroke).
Notably, one should use a dial gauge on piston to determine that TDC and not the XS Charge rotor marks: something weird is going on here and those marks are among the suspects. Absent a dial gauge, fashion a rod to carefully insert in the spark plug hole to verify piston TDC. The hole angle will try to wedge it against the piston crown – avoid that.
Remove the right “points” cover,
Observe the R. cam end and locate dowel pin (or hole) on the cam – it must be at 12 O’clock on a line through crank & cam centers. Also note the T mark on rotor and verify it is correct.
Report results for further pondering.
So with that one is it a points setup on the one side and the electronic pickup on the other? Mine is a 81 so i guess i would need the points setupI've never had any problems with Boyer Bransden on my XS and several other bikes.
Good thing i just sent you my pickup a couple months ago…Yours is an 81. It came from the factory with a first generation electronic ignition.... the TCI. It's still a damn good, reliable system. The original alternator is also a good reliable system once it's sorted.
If it were me, I'd put the original bits back on it.
Pamco folded up and went dark coming up on two yrs ago now. Not really an option anymore.
No, with the Boyer, it's fully electronic. The static plate and the rotor plate fitted to the camshaft replace all the points gubins and you get rid of the mechanical advance mechanism too. Easy to set up, then fine tune with a strobe and you never need to touch it again.So with that one is it a points setup on the one side and the electronic pickup on the other? Mine is a 81 so i guess i would need the points setup
