1. Having trouble logging in? Try closing your browser and re-opening it. If that doesn't work, try a different browser or device. The site will be updated soon to resolve these browser issues.
    Dismiss Notice
  2. Dismiss Notice
'82 Bar Hopper
Discussion in 'The Garage' started by Rhy650, Jun 20, 2021.
  1. Rhy650
    Rhy650 XS650 Addict XS650.com Supporter
    This thread will outline my modifications to the last of my Dad's XS650s. This bike is an 1982 which has had some fairly substantial frame modifications. Dad built this bike approximately 10 years ago, but never rode it much. He always referred to it as a "bar hopper" which I believe is because it was somewhat unreliable. Dad always enjoyed building them much more than riding.
    Here is the bike as it stands today:
    The original plan was for this to be my first project bike, so I have no qualms with modifying it as I see fit. The first step was to address the rusty tank and carbs. Good thing I have recently had some recent experience with this!
    I first did a slosh with some screws and acetone to eat away at some of the varnish. From here, I rinsed and let some Evaporust sit for a day or so. That stuff works great! The seams looked pretty rough, so I decided to use a POR15 kit that I had laying around. This whole process took most all of a weekend, but it turned out really well.
    From here is was onto the VM34s. This is my first time messing with this style of carb and I found them to be very easy to work with. I disassembled them and got out all the nasty rotten gas with a carb dip. From here I blew out all of the passages and looked at my jetting. I found a great guide that helped me with this. The carbs had a 159-P6 needle jet, a 6F9 needle, #15 pilot, and a #175 main jet. From the guide, I decided to try and increase the pilot to a #22.5 and the main to a #190. I took out the air jet all together.
    Got these all mounted up and will soon begin tuning. I am going to let the POR15 cure out for a good long time before I add any ethanol-free gas to it.
    Looking down the road, I'm not totally sure what else I am going to do to this bike. I am a little excited about not having to stay true to any factory specification. If I remember correctly, the engine has a 750 kit in it and I think he did a cam and valves, too. I have been wanting to try and re-phase an engine... It is also in need of some new paint. The electrics could be cleaned up quite a bit, as well. Stay tuned!
    RustiePyles, Mikey, 2XSive and 4 others like this.
  2. 5twins
    21,923
    15,470
    813
    Mikey, Rhy650, 2XSive and 2 others like this.
  3. Mailman
    :popcorn::popcorn::popcorn:
    Mikey, 2XSive, Jim and 1 other person like this.
  4. Rhy650
    Good idea! I hate how they stick out like that.
    Mikey likes this.
  5. 5twins
    21,923
    15,470
    813
    Well, I think they're going to stick out no matter what, but hopefully the angled version won't jam into the frame like that and bend the filter.
    Mikey and Mailman like this.
  6. Rhy650
    I have a couple of questions about these carbs that I have not been able to find a satisfactory answer for. Mainly, what is the best practice for routing the vent lines from the VM34s? I understand the lower hose from the bowl is something like a gas overflow, so I imagine it should aim somewhere it is (relatively) safe to leak gasoline. What about the other hose? Does it need to be connected to vacuum? Speaking of vacuum, where would I connect my manometer to sync the carbs?
    Mikey and Jim like this.
  7. gggGary
    gggGary On the road of life I'm a speed bump. XS650.com Supporter Top Contributor
    Both are open to atmosphere. Though an argument might be made to the advantages of routing the top hose inside the air filter AFAIK this is seldom if ever done.
  8. Mailman
    Ive been wondering about this, you say you removed the air jet? Is it not needed? Why did you remove it?
  9. Rhy650
    Because I am aimlessly following a guide I found on the internet! ;) The author of this guide seems to REALLY KNOW his subject matter.
    Mailman, gggGary and Jim like this.
  10. gggGary
    GLJ, Mailman and Jim like this.
  11. X77S
    X77S Let's do this!
    Possibly the ol mystery shopper experience here?
Share This Page
