Best I've got so far; translucent squeeze bottle, a mix of 2 stroke oil ( I ended up with a case of it) and WS2 powder. A large machine nut lives inside because the tungsten is heavy, the powder quickly settles out of suspension.
Shake, slide the nut around til mixed well, apply. My cable goto is make a tape cone on one end, hold cable in a vice, bottom in a tray, add oil, WS2 mix, walk away. Next day the excess oil has puddled below and whole cable is lubed. I always apply it dry to rubber seals especially fork seals and the inside of rubber dust slider seals with a Q-tip I keep in a small bottle of the dry powder. The black rubber turns silver and it seems to stay that way. Then lube with lithium grease, install.
So use dry where you can, mixed with oil to help get it deep in joints.
Just lubed up the pole lopper blades/pivots with the mix.
A few years ago the old Farmall H transmisson gears were howling. I guessed the end was near. After checking found it was low on oil (capacity 6 gallons! of 90W) just before mowing I also threw in a bunch of WS2 powder, haven't heard a groan from that tranny since. I'd love to try some in an XS motor but strongly suspect it'd be the end of the clutch plates working.
