Big ass phone holder.
I thought it was a tablet holder actually to bolt to the front dash area of your van go project.
Only about 6 or 8 more to print.
Better get on that. We need this to sit in the inspection room for 3 days before it gets looked at and sent off to the customer.
I’m about to pull the trigger on a Bambu a1. Heard it’s set and forget. Also, if you have windows and want to learn or know fusion 360, there’s a free plugin called gridfinity. You can 3d print a square grid, then there is a template basically what you just made with the corresponding grid on the bottom and you can make it so you can put torx or whatever your heart desires and it will lock into the grid
Woooooooooo....fancy!
I'm happy with my A1, waaaaaay faster than the old Creality. It'll do me for the foreseeable future.
Which Bambu printer did you get, Al?
I got the P1S with the AMS II spool feed.
It has a dryer built in.
Uhhhhhhhh...that video is over TWO YEARS OLD!
Would any of the Carbon Fiber filaments work for this?My Speed Twin 900 came without a centerstand. Even worse, parts of the engine hang below the framerails so I can't use my little scissor jack on them. But for the low low price of $350 I can order one and bolt it on to the factory provisional centerstand brackets.
Or.... for the even lower lower price of $100 I can order some ¼" plates cut from SendCutSend and weld up my own to use for maintenance work with my little scissor jack.
Designed a little cheapo prototype just to make sure my base-to-center and ear spacing are correct. Mind you, I will have plates that tie the two A-legs together. The final design should actually be somewhat reminiscent in shape of the front motor mount of our beloved XS's. This was just to check my dimensions.
I shouldn't need to use the bike lift with the final product, but I needed the lift so that I could tie the bike down centered while fitting the prototype.
The prototype isn't actually supporting and weight of the bike. I simply hand turned the scissor jack crank until any slack was taken out.
View attachment 372518View attachment 372520
Some of you may be thinking "can't the idiot just use the scissor jack on the ears of the centerstand brackets? Why's this guy always gotta overcomplicate shit all the damn time?"
1.) I initially tried that, but it was sinking into the rubber pad, which I don't want to remove.
2.) I was able to, using a ⅛" thick piece of 2" wide strip steel, but it gave me the heebie-jeebies since the center of gravity was inside such a small (7" wide) contact patch. I very carefully lifted the back tire up just enough to spin it freely so I could clean, oil, and adjust the chain. My new idea is to make my prototype's baseplate the same dimensions as the jack, so I have all that extra contact patch, which will let me breathe easier when I'm lifting the back wheel up.
Stay tuned!
Edit: if @Adamc could go ahead and voice my thoughts to the moron at Triumph that made the ultimate terrible decision to deliberately fail to include a centerstand yet provide brackets for one, I'd appreciate it. I probably wouldn't have had a problem paying an extra $350 on the MSRP if they put one on from the factory.
Not sure my printer can print carbon fiber. I might be able to (???) if I change the nozzle.Would any of the Carbon Fiber filaments work for this?
ABS-CF maybe the way to goNot sure my printer can print carbon fiber. I might be able to (???) if I change the nozzle.
But being a machinist/designer with a TIG welder in my garage, I think getting plates cut out and shipped to my house and welding it all up in my garage will be easiest for me.
Honesty, printing using a CF filament never occurred to me before you'd mentioned it.![]()
