My Vintage Honda buddy stopped by and we commenced to figure out why was no Spark. So here’s the sequence we used and what happened. So the Battery was 12.4v. With the iggy switch and kill switch on 11.2 at the coil on the R/Y wire. So not understanding why there was a 1v drop we jumpered the coils directly to the battery. Still no spark. We isolated the grounds, still no spark. We eliminated the points and mind you there was voltage to the points, but by jumping power to the coils, unplugging the points and scratching the ground on the block we are able to get a spark from the plug wire to the engine. We started with no cap because we were going basic and adding a piece at a time to figure this out. Once that worked I put the cap on and was using an in-line spark checker which I was holding because the caps ar a little different. Well we were getting a great spark then(ask me how I know! Ouch!) and we put the points back in and opened them by hand and yes we got a spark. We then put everything back in-line and I used a funnel and line to fill the bowls and gave her a couple of kicks. Started and ran! We have no idea what we did other than reconnecting things and working the mechanical parts by hand. Didn’t run well with the throttle because I don’t have the Airboxes on but it ran,didn’t sound bad and both cylinders were firing. Even a blind squirrel can sometimes find a nut……
