Solved two issues early. Found the reason for the no e-start and my voltage drop to the coils. I started tracing from the battery forward and at the solenoid I found a poor connection on the blue/white from the start button. A little cleaning and checked the voltage at the coils which improved almost 1.5v. A little starter fluid to check and she fired right up! Next I will pull the caliper and check that leak. I did notice there is no oil light on the wiring diagram.
It lights when I push the starter button. Here is the diagram I’m using but I don’t see it on any others either.
