Adopting another problem child
Fair to guys that get it and fair to guys that don’t are two totally different things.
I have the same bike and really like the patina on the tank too.
Just pulled it out of mothballs yesterday and it started with one kick!
So can anybody tell me what I’m looking at? First pic is a ‘75 dash and second is mine. What is the empty hole for?47BD023C-009C-4D17-9A7A-7D7B36604218.jpeg21CB81DA-9A6D-4AEF-871D-D0E116B0A2DB.jpeg
Im gonna have to replace mine as it’s broken but just curious what is missing?
On my 75 it's for the rear brake wear limits on the shoes
Are you in need of that cover plate? I may have one floating around in storage.
I am however I probably need the whole bracket as mine is broken off where the speedo goes and cracked on the tach side. I was thinking if I can’t find one perhaps I would try to make one out of some aluminum plate I have laying around and powder coat it
Had keys made today. Took the ignition out of the wasted dash and took it to my lock guy. Took the seat latch from the TX which he couldn’t get to work so I left it with him to work it out. Had a spare made for Patience and it worked all the locks no issues. The locks for PC however didn’t want to work either. I squirted them full of lube and left them all day. At the end of the day I was able to open the seat lock and yes there was a huge rats nest under there but that allowed me to take off the tank and tomorrow I’ll either get it to work or take it with me to the locksmith as nobody seems to know a way to pop those like the later caps.image.jpg Getting under that seat and the tank off was huge. Now I can begin to work into this bike and see exactly what she’s gonna need.
Wasn’t able to get the tank lock to work but was able to get the circlip off the latch pin and popped it up that way. I also found out the correct way to re install that latch pin. The tensioners on the spring have to be on the wrong side until installation. You can’t line things up with them in place. 70EF8ACB-97BC-43F8-8634-99DAEA547CEC.jpegOld gas looked like blood and gunk.lol. I think I’m gonna just buy new petcocks as the tubes on these are either shot or non existent 9AB37271-8BA5-4363-8935-FB103CFC5CC9.jpegF7A31B8F-C07E-415B-BADA-F8E668F3A730.jpeg I picked up 4 gal of vinegar and made sure I took before pics this time.D65FA865-0170-48E5-9975-303569250E76.jpegC99A9BD2-3082-4129-9FC6-5BE7D0D798C5.jpegD9DDBB8E-3833-4B0C-B260-CDE029C5C283.jpeg
I’ve also noticed and may have asked it here but there are no vids or directions about popping these latches so I took the lock off and made a tool that could reach, 27991437-0313-4F02-B873-6FBE6EC57F17.jpegBA30EC6B-6CAC-4C3E-9F4F-A151F364A5C7.jpegit worked so now we have a reference.
I also found out the fuel cap/gauge works fine. It’s a float on a bathtub chain that was partially dissolved lol. I can’t see it being totally accurate but it’s kinda cool.FB68137C-D55D-4437-B980-765D0D5F24ED.jpeg I washed the tank out with lots of water and dried it out before filling it with the vinegar. Let’s take a look in a few days.B922A605-0919-4284-8ECC-3EC79343CC55.jpegB31B397D-44C0-486B-A646-62E4BC4E5BD6.jpeg
Officially wheeled her inside and began to see just how bad it’s going to be. Seat pan is shot for sure but that was expected. The battery box was totally filled with rats nest and when I got down to the bottom with my shop vac it was like a brick. I ended up peeling something out of there that resembled 47 yo roofing pitch but thanks to all the rat skank it didn’t stick to the tray.B752B1EA-BB9E-4EBD-A1C0-3B648AF5BF10.jpeg4135558A-6CDD-4163-921B-64E0B0E54026.jpeg
exhaust was in really good shape with some surface rust on the bottom of the left pipe but steel wool is my friend. I didn’t check the parts diagram but there was no top brace tying the carbs together. I think I may have one lying around. I did a part # comparison between the controls, gauges and a few other parts off the TX500 and the actually have the same number so it looks like I have just about everything I need in that respect, I just need to check the wiring diagram to see if the colors match but if they are using the same parts with the same leads in different bikes I feel like it should work. I bought that bike for less than what I would pay for a good headlamp bucket so no issues using it as a doner.D862C484-911B-41CE-8644-0CE3ABFE486F.jpeg2231FF12-5CAF-4E93-ACC6-46DD54290ECA.jpeg92B3DADC-D2FC-49A9-BA51-94E918E694A6.jpeg
I have several options depending on what I find inside the engine as I’m not 100% sure why or where it’s stuck but the oil in the crankcase isn’t bad or watery. there was some corrosion under the alternator cover but just above it the points looked new.7DB4726F-5ED9-449D-A48A-91AE00C856D7.jpegACD20C65-C164-46DC-8A83-389FC8B8A587.jpeg
I also love the repair on the fork bonnets lol.E64B6F1C-E28F-47E0-A6D7-0C47B3309E93.jpeg
