Just got yet another set of Banggood turn signals in the mail today. May finally have a winner. I've had a small set of their LED signals on madness the last two years but caught flack in group rides that they were hard./impossible to see. This set will be different. (he sez) But they do have some nice features!
You do NOT need a flasher for them to work! Just jumper the flasher to supply steady power through the handlebar TS switch.
"These are bright and work just the way you want. In front the white is on UNTIL the yellow sequential turn signal is activated then the white goes out. When the turn signal is canceled the white comes back on. In the back the bright red brake light strobes for about 2 seconds then comes on solid, the red goes out while the sequential turn signal is activated. Best I've found, big enough to be seen but not too bulky. Can't be beat for this price, I'm ordering three more sets. Wire colors are standard, Black is ground, yellow is turn signal, in back red is brake light, and in front white is steady white light. Leads are decent length covered with a nice weight back sheath, with mini male bullet connectors. My only complaint is they are not visible from the side, the lights/lens are flush in the housing. If they wrapped around the end a bit or had a raised lens/reflector they would be even better. Two Thumbs up."
I'll get a video up showing operation.
All four for $10 USD! Left em hooked up to the 12 volt power supply for a 1/2 hour steady no issues.
Anyone else found turn signals they like?
