All things rubber
Myuncles650
Idaho
Hi All, looking to learn more about best way to source parts (1974TX650 taking it down to frame - needs every rubber piece replaced). Is there a mostly one stop shop for all rubber grommets, mounts etc (turn signals, tank mount, handlebars, side covers, rear fender)?
Or, is it best to find OE number and search? Found a place called Yambits which has a lot of pieces but wanted to hear what you all do if possible. Thanks in advance for sharing.
I'm messing with my '74 too. I've gotten reasonable facsimiles of the OE parts from Yamahaxs650.com & Mikesxs.com. Some ok - like kick & shift rubbers, some junk...like side cover latches. None of it is really as good as OEM. Alot of McGivering and trips to the hardware store.
Yamaha OE parts are really expensive if it is available. I think much is NLA. I'm interested in hearing from others too.
My own experience over the last year with my 650D, I replaced just about every rubber part on the bike. If possible, the Yamaha parts are worth buying if they're available. The ones I took off are ~48 years old. I doubt the aftermarket ones will last three years, it's obvious the quality isn't there. So it's basically a choice of quality and longevity versus price. FWIW I expect it doesn't matter so much where you buy aftermarket rubber parts, I reckon it's likely they all come from the same factory in Taiwan.
Yes, pretty much all the aftermarket rubber parts are garbage. I know from personal experience that the footpeg rubbers are terrible, they'll wear "bald" in a couple seasons, lol. The rubber covers for the side cover tabs are also junk. Luckily, originals are still available, as are the grommets for the later plastic side covers. Shift and kickstart rubbers are also available. I watch eBay for most of this stuff because it's often cheaper, footpeg rubbers especially. I've even bought nice used originals because they last almost forever. My '78 still has the originals on it and while they're worn a bit, they still have life left in them.
Not sure why you did get any feedback on this topic (maybe copious other tire threads IDK).
On bikes of this vintage, I have had good results from Bridgestone Battlax BT46's and Avon Roadrider MkII. Avon probably the "better" tire, but also more $.
