Almost There
Uncle Frank
Australia
Well I'm just about at the end of my current project - an XS650C with a rebuilt 256 engine. I don't know the history of the engine so I don't know which type or year of stator is fitted. I have replaced the brushes and brush holder with new ones from Geoffs XS here in Oz and I am using a solid state rectifier/regulator from XS650 Direct. The wiring is complete apart from the critical wiring of the stator to the rec/reg. The stator wires are green/black and I have them running into the rec/reg wires which are green/brown. Where I'm unsure is do I wire the green from the stator into the switched positive on the rec/reg as per post 1980 diagrams I have seen on this site or do I wire the black from the stator onto the earth wire. In either case I assume I will need to use the nylon screws on the inner brush?
Thanks in advance.
Thanks in advance. View attachment 342133View attachment 342134View attachment 342135
The green wire goes to the green wire. the brown wire goes to the brown wire. the black wire goes to the black wire.
The brown wire is the 12 volt power supply and is what the regulator is measuring. the green wire is to switch on or off the magnet on the generator. the black wire is the earth or ground.
Don't put the brown wire on the black wire, it will short out the power.
You'll need to make sure you bought the right kind of regulator for your system. There were two versions of the charging system used, an early one up through '79 and the later version from '80 on. The difference is in how the brushes are wired. The early system like yours grounded the inner brush full time and needs a regulator than feeds and controls power to the outer brush. The later system is kinda the opposite - the inner brush is powered all the time and a different type of regulator that feeds and controls a ground signal to the outer brush is needed. Details are here .....
https://www.xs650.com/threads/diy-reg-rec-5twins-and-jim.55842/
Yes Sir but I believe we in Europe and Oceania is One year later
I have 1980 -s With Points and older system charging Stock and ordered for that year model 1980 from China
Fried probably immediately the regulator inside Excellent help from the seller after
So please don't hook it up before sure
The people at XS650 Direct have assured me that this is the correct regulator for the earlier system.
So given that it is the earlier type regulator I should wire it up like this?
No, you won't need the nylon screw mod if your regulator is the correct power switching type (type B). You only do that when adapting a type A (ground switching) regulator for use on your older style system because it also involves rewiring the brushes and making the inner one "hot" all the time. If you didn't change it's mounting screws to nylon, it would simply short out.
Cheers and beers 5twins.
Yes, that looks correct. If that combined unit gives you problems, I highly recommend going the DIY route. It's much cheaper and very reliable.
Well the worst has happened. I've got the bike fired up but no charging. I've gone about this assuming my 256 engine has the older type alternator but maybe it doesn't? How do you pick the difference between the older and the new type?
According to the pic in your 1st post, you have the older type. The "tells" are how the brushes mount and are wired, and whether or not the timing marks are cast in the housing. Your inner brush is mounted by 3 screws that screw directly into the housing, and that grounds it full time, and you also have the cast-in timing marks. The later alternator uses the same brush in both spots, mounted with one screw, and that screw is isolated from the housing ......
The timing marks are on a little bolt-on plate, not cast into the housing anymore ......
The combined unit has 2 pigtails. They should clip straight into your loom plugs. Green and brown are the regulator side.
Check they are going to the correct colourd wire
Normally this has a Bl, (earth) to the brushes but that is now on the regulator plug side of the combined Reg/Rect to the brushes
Make sure the Reg/Rect is earthed. If bolted to the battery box you need to run an earth wire from the frame to the Reg/Rect.
From the 74 diagram.
Thanks Skull. I don't have separate earth for the reg/rec and it is bolted to the battery box. I'll put one on tomorrow and see how we go.
Thanks 5Twins - I'll do as 650Skull suggested and run an extra earth from the rec/reg.
Well this is the latest. Battery shows 13.0V, when key is turned on it drops to 12.9V. When running it jumps to 13.3V. Attaching a separate earth to the rec/reg makes no difference. Any ideas anyone?
By the way thanks for all the help so far:)
