Convert to standard 3 phase bridge rectifier and automotive regulator? Anecdotally, based on what I see posted here, those combined reg/recs seem more troublesome?
Which is exactly what I will do. I thought I had an earth fault in the rotor but it was earthing through the brushesYes, that looks correct. If that combined unit gives you problems, I highly recommend going the DIY route. It's much cheaper and very reliable.
Highly recommend DIY. You'll have a solid, reliable charging system at very low cost with industry standard components.Which is exactly what I will do. I thought I had an earth fault in the rotor but it was earthing through the brushes![]()
Agreed, easier to troubleshoot than a combined black box too.And I also like the idea of a separate regulator and rectifier. If there's a problem with either one, you can just replace that item.
My Napa Echlin VR1010 has arrived. I has the four wires - green, black, orange and yellow. I will connect the green to the green brush wire, the black to the black brush wire and earth, twitch the orange and yellow together and connect them to switched power. Does that sound about right?And I also like the idea of a separate regulator and rectifier. If there's a problem with either one, you can just replace that item.
Nice work 5Twins. Thanks for the adviceYes, the way you intend to wire it sounds correct. If you plan to mount it where the original regulator was then the pigtail will be too short to reach the connector on the harness (on top by the battery). So, you'll need a "jumper" harness. I used 4 wires and combined the red (or orange) and yellow up at the harness plug .....
To keep the regulator end from coming unplugged, I added a couple cable ties ......
The jumper harness is then fed behind the battery, between it and the inner rear fender, up to the harness plug .....
It's possible that the regulator is working fine and it's set point is 14v? I know the set point is sometimes written on the regulators. I think mine is 14.5v. Others here know more than I though.So I installed my new regulator and rectifier today. Still no joy - now volts build up to around 13.9 - 14.0 and hold steady there. Increasing revs makes no difference. I double checked the readings at the rectifier but no difference. Not sure where to go from here.
With engine not running:
Battery volts - 12.8
Voltage at switched wire into regulator - 12.6
Voltage out of regulator - 11.5
Voltage at brush - 11.4
Resistance for each phase - 0.5 ohms
Resistance across rotor - 5.0 ohms
With engine running:
AC volts for each phase - 11.4 to 11.6
Beautiful! Looks like it's all go then. I'll post some pics and details when it's on the road.Yes, the set point differs on different regulators. But 14v will keep your battery charged. I ran mine for years with the original regulator only putting out the high 13s and never had any dead battery issues. Once I learned more about the charging system and that the original regulator's output could be adjusted, I "fixed" it, lol. I set it to the low 14s which from my research I concluded to be about ideal.
All of the VR115s and VR1010s I've tried so far have put out voltages in the low 14s. And something else I like about them is that they reduce their output by a few tenths of a volt after the battery is replenished from electric starting, dropping to the high 13s or right around 14. The factory combined reg/rec on my '83 doesn't do this, always putting out it's max of the low to mid 14s when the bike is revved.
